Voyager on clean 1.4.5 install
    Posts: 1932 from 2003/10/19
    I have got a clean install working great on my Peg and I want to get Voyager pulled from the 1.4 CD working. It does nothing at all now when I click its icon. Can anyone give me a clue to the steps I need to follow for a woking install of it?
  • »04.07.05 - 03:24
    klesterjr
    Posts: 196 from 2005/4/1
    You might try downloading the latest version of Voyager from Vapor and comparing the archive to what you have in 1.4.5.
    My guess is that you're missing a few Libs (and MUI libs) that Voyager needs.
  • »04.07.05 - 03:33
    You cant get the latest MOS version that came on the 1.4 CD. Who knows though. I am using Aweb now and its okay, but I like V a lot better.
  • »04.07.05 - 03:35
    klesterjr
    I know -- I meant to use as a "guide" for what libraries you need.
  • »04.07.05 - 04:58
    Brumiga
    Posts: 276 from 2004/4/3
    Hello Acill,
    Your problem has two causes : tearoff stuff and vapor libs. Install script of morphos 1.4.5 has removed them from their respectives mossys subdirectories because it removes all the stuff away between this release and the earlier ones 1.4.x. Install/reinstall tearoff stuff to sys:classes/mui instead of mossys:classes/mui and vapor libs to libs instead of mossys:libs. Doing so this stuff will be preserved on new install or update of morphos because away from mossys subdirectories.
    Brumiga
    [ Edited by Brumiga on 2005/7/4 10:34 ]
  • »04.07.05 - 07:25
    Posts: 2730 from 2003/2/24
    What does snoop dos say about it?
  • »04.07.05 - 07:25
    I figured it out. The icon was looking in sys:apps for the program and
    I had to edit its location to work/internet. BUT my fonts look like
    ass!!! I forgot just how much work I had into my old install.
    Sheesh....
    [ Edited by Acill on 2005/7/4 5:12 ]
  • »04.07.05 - 11:11
    judas
    Posts: 175 from 2005/1/14
    which version of Aweb are you using ?
    I downloaded some sourceforce-binaries, but
    couldnt get them to work .. do I need OS4emu ?
    I'll try again, if I know the direction to take ;)
    bye
  • »04.07.05 - 12:30
    Its a beta one of the devs gave me to try. I put it on
    homepage.mac.com/acill if you want to try it.
  • »04.07.05 - 15:22
    Posts: 1087 from 2003/3/24
    Please put it on net i would love to try it!!!
  • »04.07.05 - 20:24
