Firmware update of a Pioneer DVD-RW drive under MorphOS
  • rms
    rms
    Posts: 606 from 2004/11/27
    I use a Pioneer DVD-RW DVR-109 drive which has firmware v 1.17 I would like to update to latest v 1.55.
    Does anybody know how to do this under MorphOS?
    Thanks for suggestions.
    Regards
    Christoph
  • »01.07.05 - 03:57
    analogkid
    Posts: 711 from 2004/11/3
    the update tools mostly need Windows or DOS. No chance under MorphOS
  • »01.07.05 - 05:00
    Phantom
    Posts: 381 from 2004/9/7
    There is nothing for MorphOS, but you can update your firmware to a bucket (PC) (if you have one) and then plug it again in your Pegasos  :-P
    [ Edited by Phantom206 on 2005/7/1 13:07 ]
  • »01.07.05 - 09:06
    magnetic
    Posts: 2129 from 2003/3/1
    RMS
    You must use a pc to flash the firmware..
    Also, does this drive support DECSS with Mplayer and playing of Commercial (encoded) DVDs?
    magnetic
  • »02.07.05 - 20:35
    Posts: 1932 from 2003/10/19
    You may be able to do it using boches or dosbox. I know I can use VPC to flash mine on the Mac but only through USB. Its worth a try at least.
  • »03.07.05 - 10:43
    magnetic
    Good alternative suggestion, but I wouldnt recommend doing so as there is a danger for a crash or freeze and this will kill the drive..
    magnetic
    use a pc
  • »03.07.05 - 23:27
    Using a PC is the best way. I recomend going to a thrift shop and getting the oldest PC they have for just a few bucks. Install freeDOS on it and your set.
  • »04.07.05 - 01:53
