Posts: 918 from 2004/1/24
Well, I might be totally wrong here, but afaik only emu10k is supported atm, so I guess any SBlaster Live would be good enough. I use one instead of the onboard sound because imho the quality is better and it handles volume much better. On the other hand, onboard sound seems good enough for most people.
Oh, and you get surround with the SBLive, but since I'm not using that, I can't report how good it is.
