Posts: 268 from 2003/4/20
I don't think it's possible to mount Amiga partitions in MacOS but there are other options:
There is a program that let's you connect linux partitions in chooser, it's called:
Netatalk.
Another option is to configure a ftp server in Linux and use a ftp client in MacOS.
More information about both methods can be found on:
MacGuru HQ, see topic 'How to Transfer Data between Linux and MacOS Running on the same Workstation'.
I haven't tried it because I don't really care for MacOS on my Pegasos.
