Kaffe on MorphOS
    micken
    Posts: 42 from 2004/6/7
    Kaffe compiles fine on MorphOS, but it has some, I guess, memory problems when loading classes. If every exit is disabled it starts and loads a lot of basic classes and then after a very long time it exists. It also requires that all classes,including system, has the write enabled protection bit set.
    MorphOS hangaround :)
  • »21.06.05 - 18:41
    Posts: 1081 from 2003/3/24
    What is Kaffe? Is it a sort of Java?
  • »22.06.05 - 10:49
    micken
    Kaffe is a opensource java jvm.
    www.kaffe.org
  • »22.06.05 - 13:20
