OT: OpenBSD and Voodoo3-3500
    _coliN_
    Posts: 70 from 2003/4/30
    Hello!
    I want to test OpenBSD 3.5 on my Pegasos-I,
    and have installed it succesfully.
    Now I want to configure X11 with my Voodoo 3-3500 graphics card, but dont know how it works.
    The xf86config - program doesnt support such a card, and with the generic 3dfx-driver I get only strange coloured output.
    Has anyone a solution?
    Greets! Boris
  • »14.06.05 - 08:43
    Chain-Q
    Posts: 350 from 2003/10/12
    You'll probably have nothing more than that. The "strange coloured" output is a so-called 'endian' bug: the driver tries to handle the Voodoo in 'little-endian' mode (reversed byteorder, used by Intel CPU's for eg.) while the PPC uses 'big-endian' (normal byte order).
    So it's a known flaw in X11's 3fdx driver on all platforms using big-endian byte order (incl. LinuxPPC). It needs to be fixed, but no one took the job yet. You have even luck that it works at some level: Voodoo4/Voodoo5 doesn't work at all, IIRC.
    [.Hosting AmigaSpirit.hu.]
  • »14.06.05 - 08:56
    _coliN_
    Hello!
    So how can I get OpenBSD running with a GUI?
    A new graphics card?
    What is with the generic 3dfx-driver of an OpenBSD for MacPPC,
    or doesnt exist in this port such a driver?
    Iam a newbie in OpenBSD/Linux:
    perhaps I can run OpenBSD with KDE?
    Greets!
  • »15.06.05 - 12:19
