drawing software
    Pearly
    Posts: 43 from 2005/6/8
    What are the popular software(s) for 2-D art for pegasos ?....I not looking for an expensive program , but something that addresses the basics.
    If there aren't any... would the amiga art programs have to run on emulation?
    I need something that includes a good paint program ...as good as TVPaint , DPaint4,..etc.
    And a good image enhancer also ... I have no experience with any Pegasos applications.
    any suggestions would be appreciated.
    [ Edited by Pearly on 2005/6/9 18:37 ]
  • »10.06.05 - 03:36
    aliem
    Posts: 85 from 2003/12/11
    Here I have:
    TVPaint, ArtEffect 3.0, ImageFX (in the SuperBundle), FX Paint lite MOS version, XiPaint 4.0 (with some problems), DiamondBox 1.12, 4p and Pixel32 (this will be the best when updated by the author).
    bye
    [ Edited by aliem on 2005/6/10 5:15 ]
  • »10.06.05 - 05:14
    Pearly
    aliem..Thank you ... I think? ...
    [ Edited by Pearly on 2005/6/9 22:35 ]
    [ Edited by Pearly on 2005/6/9 22:53 ]
  • »10.06.05 - 07:34
    stefkos
    Posts: 96 from 2004/2/4
    i know at last 2 programs in development...
    if you want some info ask on priv
  • »10.06.05 - 11:00
    Pearly
    stefkos:
    ask on priv?
    Im new to forums and not knowledgable on the 'underground' ...or anything else ...If there are no art programs then OK ...
  • »10.06.05 - 19:10
    td741
    Posts: 224 from 2003/4/2
    It depends by what type of art program you're asking about?
    There are some more geared towards photo manipulation, others geared towards creating fresh 2d bitmaps, others geared towards vector-drawing.
    Some of them are MOS Native, others are just Amiga 68k-PPC software that works with MOS. ;)
    Steph
  • »10.06.05 - 19:14
    Pearly
    thank you td741 ...could you look at the first post on this page ?
  • »10.06.05 - 22:22
    stefkos
    this programs are under developement, when developers will finish it i dont know, they need free time to do that.
    if you are gfx artist and want more info just find my email somewhere and ask.
  • »10.06.05 - 22:43
    td741
    D'oh. :P
    Well, if you like TVPaint it should work on MorphOS. I've heard that some people also got PPaint to work. Though I haven't given it a shot. :P
    My Pegasos has FXPaint (MOS), ImageFX (with PPC modules), Art Effect (68k) and DrawStudio 2 (68k) installed. (DrawStudio needs to run the smartwin hack in order to run unfortunatly. This hack may not work in future revisions of MOS.) I also use Cinema 4D (68k).
    Don't worry if an application is Amiga 68K, MorphOS's JIT makes the applications run a lot faster then you'd thought possible. ;)
    Steph
  • »11.06.05 - 04:52
    Pearly
    td741 ...thank you for the info ... all good ideas.. I'm very anxious to try the new software ..
  • »11.06.05 - 07:03
