to mount or not to mount
    GMKai
    Posts: 257 from 2003/4/7
    Hello I gave the cdda-filesystem a try and found it usefull to access audiocd-tracks directly via ambient.
    but after ejecting the cd, the icon is not removed. what can be done to remove the disk completely. there must be a way as removing usb-sticks works quite good.
    mount das not have an option to do so and the command unmount is unknown. any hints?
  • »08.06.05 - 17:55
    roschmyr
    Posts: 210 from 2003/2/20
    you can try
    assign volume: dismount
  • »08.06.05 - 18:00
    Ingo
    Posts: 103 from 2004/3/19
    the problem is ambient doesn't refresh.
    f.e. when i mount an iso and want to get rid of it, i do the
    following:
    assign dismount vol:
    assign remove vol:
    then i put in a real CD, close the drive, wait for it to show up in
    ambient and then remove the CD. This makes ambient refresh the
    desktop. the mounted iso is removed.
    I don't know if there is a more comfortable way to get ambient to
    refresh but this one works (at least).
  • »08.06.05 - 18:31
    Posts: 408 from 2004/7/15
    I think i understand the reason of this problem.
    This is because "Assign" tool doesn't post IDCMP_DISKREMOVED after removing a volume.
    In fact this is dos.library's fault as m68k Assign also doesn't post IDCMP_DISKREMOVED.
    I will consider fixing it in unmorphos.
    iPod, iBook, iMac,... iRobot?
  • »10.06.05 - 03:13
    jcmarcos
    Posts: 1178 from 2003/3/13
    Sonic wrote:
    <snip>
    What is "unmorphos"?
  • »10.06.05 - 05:21
