the mysterious nlist.mcc
    Bladerunner
    Posts: 418 from 2004/2/19
    Well, this is really strange, I even start to believe my Peg is bewitched ;-)
    This is my Problem:
    After the Simple Mail vs Yam I thought I `d like to give Simple Mail a try. No Problem so far, started it, then it moaned about wrong nlist.mcc
    Version (20.115 is needed) I checked in mossys:classes/mui (which should be loaded before anything else afaiu) the nlist.mcc there was according version FILE nlist.mcc: 20.115
    And now it get strange:
    If I do version nlist.mcc (which should display the loaded nlist) it says 20.111 ????
    Ridiculous eh?
    I did search on my entire Harddisk, and deleted every other found nlist.mcc but the problem is still there ?!
    Is there a way to find out from which place a library is loaded? Scout also just shows me what library is opened, but not from where it is opened. It is totally mad.
  • »05.06.05 - 14:33
    Tronman
    Posts: 209 from 2003/3/3
    You had this issue too?? I went through this a year and a half ago,
    with the nlist.mcc and YAM v2.x. I very thoroughly documented my
    trevails in emails to the core gods but didn't get far. THey kinda
    said I was crazy, so I thought I was. Long story short, I am running
    YAM 1.3.5 and it works fine, but its kinda primitive. I use it as the
    'backup' email in case my Mac has a problem-which it does occasionally
    when one of my Clinton-era hard drives decides to go tits-up :-(
    I miss the Clinton Era :-(
    Anyhow, I was never able to solve this problem, I did all the same
    things you did. The version checker that you use when checking an
    icon's version as from Ambient, seems at times different than the
    shell 'version' command-it is possible for two different numbers from
    the same file it seems. I guess they'll fix this bug too when they
    can.
  • »05.06.05 - 16:16
    Henes
    Posts: 507 from 2003/6/14
    You can use snoopdos or snoopium to know where the library is loaded
    from.
  • »05.06.05 - 18:13
    Bladerunner
    Henes: Well I did this first of course ;)
    But it didn`t show the path?! (Perhaps because the lib was allready loaded) Anyway I tried snoopdos again, including it during startup and that gave me the hint: There was a nlist.mcc.elf in sys:classes/libs/mui which i have completly overseen, this one was older.
    But out of curiousity, is this a bug or a feature?! I thought that Mossys: has allways priority over the stuff located in Sys: even if it is named .elf ?
  • »05.06.05 - 22:57
    Posts: 1932 from 2003/10/19
    I had the same issue. I ended up having to rename all the nlist.mcc on my drive and replace it with the new version. Though in the 1.4.5 release I have the proper ones not in mossys: so I removed all from sys: and it seems to have solved all my issues.
  • »05.06.05 - 23:28
    Tronman
    You know, I haven't tried it again with MOS 1.4.5. Maybe I should.
    Will YAM display html in emails? It seems many emails nowadays have
    it, needless to say they look horrible in old school YAM 1.3.5 :-/
    I notice you included snoopDOS in startup, I shoulda thought of that
    :-( Back in the day, some Amiga mag had an article about running such
    a utility early in startup to catch bad things happening-I followed
    the article's advice and got a much more stable Amiga as a result but
    that was back in the 3.1 days. Good times.. :-)
  • »06.06.05 - 04:38
