Powersdl library backward compatibility
    Brumiga
    Posts: 276 from 2004/4/3
    Hello,
    I think that there is a backward compatibility problem between the latest release of powersdl librarys and the earliers. And so many little game that came these last months and written with the current version at this moment have problems : some do not start, some other have a strange behavior when started, Bolcatoïd hangs when i start a party and i must use the first version after having neutralized the current one by renaming it to let this game be playable and to play with other games i must do the opposite handling. Should not a library stay backward compatible when new releases come ? Otherwise is there a workaround or will i only have the solution of deletion of the unworking games ?
    Brumiga
  • »03.06.05 - 11:33
    Posts: 1521 from 2003/2/24
    It is backward compatible but it seems something is broken in V11. Bolcatoid worked when I tried it last time but I check it again.
    What other games are giving problems now? What is strange behavior when started? Wrong colours?
  • »03.06.05 - 11:49
