DVD burning?
    Spidey
    Posts: 568 from 2003/2/24
    Hello everybody,
    What's the status with DVD burning software?
    How can I read DVD's with my Peg?
    Thanks in advance,
    N.
  • »06.06.03 - 09:15
  • scf
    scf
    Posts: 54 from 2003/6/3
    AFAIK AllegroCDFS can read dvd
  • »06.06.03 - 12:08
    Spidey
    Aha,
    So AllegroCDFS works with Pegasos scf? :-)
    Do you know where I can get or purchase this product?
    @everybody:
    Anybody tried playing DVD-movies or so?
    If "yes", which program was used?
    Spidey
  • »06.06.03 - 13:11
  • scf
    scf
    I haven't Pegasos, so dont know works it or not.
    Look this http://www.elbox.com/downloads_fastata.html
  • »06.06.03 - 13:40
    Posts: 38 from 2003/4/3
    AllegroCDFS does NOT work on anything else then an Amiga with an Elbox Fast ATA Controller. However, the builtin CD Filesystem of MorphOS supports DVD reading.
    BUT most DVDs are encrypted, which is NOT supported because of legal/licence issues.
    If you are lucky, AMP2 can play your DVDs, but it is somewhat unstable since it is beta since some time, and it does only work with little (or was it bit? Radeon doesn't work, Voodoo does) Endian Modes.
  • »06.06.03 - 13:57
    Spidey
    Hi scf and Saint,
    It looks like we'll have to wait for some "official" DVD-support for MOS! :-)
    I was hoping we would have some options using Amiga utils to run DVD movies and so.
    I'm a patient guy, I can wait.......hopefully :-D
    Spidey
  • »06.06.03 - 14:32
  • scf
    scf
    Saint, why it works for me?
  • »06.06.03 - 15:45
    tokai
    Posts: 1289 from 2003/2/25
    1. mos cd filesystem supports dvds. there mounted without problems.
    2. u can use frogger (2.06) to watch the vob files. But frogger can't handle crypted dvds. and has no support for the required audiocodec yet.
    3. to get sound and have support for crypted dvds u can use mencoder (check out morphos-news.de -> softwaresection). Simply convert them to divx and watch.
    4. I'm sure the Author of mencoder works on a port of the mencoder movie-player. Then it whould be possible to watch dvds without any problems. Maybe u should ask him per email. If he recognizes that theres really need for such application then it will come true.
    Thanks for your attention. :)
  • »06.06.03 - 17:48
  • jah
    jah
    Posts: 69 from 2003/3/24
    >4...
    mencoder movie-player is mplayer, its another person who port it
  • »06.06.03 - 19:14
    Spidey
    Thanks again for the info tokai :-D
    Spidey
  • »06.06.03 - 21:33
    Spidey
  • »11.06.03 - 06:15
  • jah
    jah
    last frogger seems to have serious troubles, it refuse to replay
    mencoder encoded movies
    previous versions works fine, mplayer too
    -mplayer can read vob without probs
    -no options to change, only change the player ;)
  • »11.06.03 - 14:30
    Spidey
    Hello jah,
    Thanks for the info.
    Now I have to find mplayer.
    In the meanwhile I found mpeg2decodeWOS.
    This one also works, but I didn't figure out how to stop the movie :-)
    Spidey
  • »11.06.03 - 17:19
    Henri
    Posts: 73 from 2003/5/14
    MorphOS-mplayer-port is here:
    http://louise.amiga.hu/index.php?MENU=5_5
    Regards
  • »30.06.03 - 21:15
