Poseidon v. in MOS1.4.5 ???
  • JKD
    JKD
    Posts: 456 from 2003/4/4
    I read that the new boot.img contains Poseidon 2.2 but seem to recall 2.2 MOS archive having uhciusb.device v.50.10
    When I version after booting with the new boot.img, it tells me the resident is 50.8 - anyone?
    I also get a hang on startup with my card reader plugged in (same as in MOS1.4 and 1.4.4)
    [ Edited by JKD on 2005/5/4 13:49 ]
  • »04.05.05 - 22:40
    merko
    Posts: 328 from 2003/5/19
    Well.. if you have problems with v50.8 you might try v50.10 from the
    Poseidon website instead. But it also seems to go the other way round,
    so if you have problems with the version on the website, try the one
    that comes with 1.4.5.
  • »05.05.05 - 14:15
