PowerSdl 10.5 and Aerty Keyboard
    Posts: 168 from 2004/11/18
    Hello, i have a problem with Azerty keyboard on powersdl.library this problem doesn't appears whith old version of this one.
    do someone has a solution ?
  • »03.05.05 - 08:21
    BatteMan
    Posts: 294 from 2003/2/24
    Use the US keyboard when you launch UAE... It's the only solution for the moment.
    /me says : "Coucou Ace" :-D
  • »03.05.05 - 08:40
    Posts: 1521 from 2003/2/24
    @acepeg
    What kind of problem?
  • »03.05.05 - 09:15
    BatteMan
    Itix : Some keys don't work (like ":")... But, it's ok if I choose a US keyboard in MorphOS.
    /me can't be more explicit...
  • »03.05.05 - 09:42
    It seems to be a problem whith the : and ; and somme letters.
    But the main probleme for me is the Ctrl key, because on digibooster it's needed to make spaces between lines.
    but i haven't tested us keyboard ...
    sure it can be easily fixed for a great coder
    [ Edited by acepeg on 2005/5/4 11:51 ]
  • »04.05.05 - 08:49
