rename ldview _____?
    Jupp3
    Posts: 1193 from 2003/2/24
    The official LDView homepage.
    Too bad I found it only after renaming my own ldraw lego model viewer ldview aswell.
    So as my software is the newer one, I probably should rename it to something else. Any suggestions? :-)
    You can see some images of my program here.
  • »03.05.05 - 12:50
    SoundSquare
    Posts: 1214 from 2004/12/1
    what is this "let's rename..." fashion thingie all about ?
    ok i suggest LDisplay
  • »03.05.05 - 13:10
    Posts: 1521 from 2003/2/24
    @jupp3
    LegoView?
  • »03.05.05 - 13:14
  • Targhan
    Posts: 2833 from 2003/2/7
    Do what everyone else does, slap "Ami" in front of it.... Okay, well maybe not. How about, LDShow?
    :idea:Targhan
  • »03.05.05 - 15:10
    Posts: 918 from 2004/1/24
    Roquefort 8-D
  • »03.05.05 - 16:59
    mdma
    Posts: 85 from 2003/5/4
    Reggae! ;-)
  • »03.05.05 - 22:39
    Posts: 1932 from 2003/10/19
    JuppView, call it that and be done with it
  • »03.05.05 - 22:39
    Krashan
    Posts: 1107 from 2003/6/11
    mdma wrote:
    Reggae! ;-)
    No way! It is taken already.
  • »04.05.05 - 05:56
