FAQ for linux = details for impatience people :-)
    magnetic
    Posts: 2129 from 2003/3/1
    Hi Dj
    You are doing a great service to the community. Your MOL stuff is great! However, your "Download" section is down on your site. I would love to get the MOL stuff. Please post to let us know.
    TIA
    magnetic
  • »27.05.03 - 15:26
    Frostwork
    Posts: 302 from 2003/4/18
    HiHo!
    Please could tell me someone, where to find the
    required libc6-Version for PPC?
    On the debian-homepage I just only find x86-version....
    Please!!!
    Bye
    Frostwork
  • »28.05.03 - 08:27
    Frostwork
    Please give me a link!
    I really can't find it...
    Thank you!
    Frostwork
  • »28.05.03 - 13:31
    magnetic
    Hi all
    I'm really confused with installing MOL on Debian. Do I have to recompile my pegasos linux kernal? I have a bunch of .deb files what do I do with them? How do I execute them? Any help is appreciated.
    magnetic
  • »28.05.03 - 17:41
    Frostwork
    Hi, magnetic!
    .deb files are packed archives...
    You can f.e. install them by clicking them in
    Konqueror...
    A Archivier-GUI is opened in which you are told
    what other archives (f.e. libs) are used to
    run the wanted program...
    Which .debs do you have? Are they for MOL?
    For installing MOL unpack the source of your
    kernel f.e. in /lib/modules/
    A pegasoslinux drawer is created there...
    cd in it and write "make config"
    You are asked several questions about the
    kernel (don't know if you are allowed here to
    answer in non-default way, but default answers worked here).
    After questions are over write "make dep"
    Done this write
    "ln -s /lib/modules/pegasoslinux /usr/src/linux"
    to make a soft-link into 2nd path.
    Unpack your MOL-packages
    cd into created mol-kmods...
    write "./configure" - after that "make" and "make install".
    Do the same with the other mol -drawer...
    I hope there are no errors in my description,
    as I'm still a linux-newbie....
    Alternatively you can download the rpms
    from MOL-Homepage and convert them
    with alien into .debs:
    "alien mol-XXX.rpm" is enough.
    Theses archives can be installed with the
    above described Archivierer-GUI.
    But make sure you have all dependencies
    installed on your system!
    to install missing ones (or to test if installed)
    write:
    apt-get install archivename
    f.e.
    apt-get install libc6
    Good luck!
    Bye
    Frostwork
    PS: Anyone got the link for the latest needed
    libc6, in order to install XFree4.3?
  • »29.05.03 - 13:09
    Posts: 261 from 2003/3/13
    djbmister Caterpillar explains in his post
    from 2003/5/27 13:22, how to install libc6.
    > ( once you have done this, type apt-get )
    > (update then JUST type apt-get install libc6)
    > (, nothing else OK!!!)
    And it worked for me :)
    At certain point, he mentions to do:
    apt-get install x-windows-system,
    wich should be x-window-system,
    without the s, but besides this
    minor thing, it didn't install XFree4.3
    for me, so i did something like:
    apt-get install xserver-xfree.
    But now that i have libc6 and xfree4.3
    installed, i have another problem, now
    my radeon 7000 works a bit, but the only
    screenmode i get is 1280*960 or such,
    wich doesn't work for MOL, and i can't
    seem to get mol running in a window.. :(((
    Felix.
  • »30.05.03 - 09:51
    Frostwork
    Hi, felix!
    Thank you for reply, but as I don't have
    internet-access on my Peggie, it's quiet useless
    to configure apt-get this way...
    But it doesn't matter:
    I'll send david (djbmister) the paypal-money
    and he sends me a "ready-to-take-off-debian-distribution" with latest XFree+KDE....
    Have a nice weekend!
    Bye
    Frostwork
  • »30.05.03 - 11:13
    Posts: 90 from 2003/4/13
    < "ready-to-take-off-debian-distribution" with latest XFree+KDE....>
    That's exactly what Mandrake 9.1 delivers up to date
    and NO beta releases for common users. I will wait foor Mandrake! (or some other distro).Meanwhile I wish you luck
    regs
    hgm
  • »30.05.03 - 12:03
    Frostwork
    Hi,lowietje1!
    Yes, maybe!
    But I have 3 partitions free for linux:
    one will stay the debian one
    2nd is for SuseLinux (buyed with the peggie,
    but doesn't work :( )
    3rd for Mandrake or YellowDog
    Bye
    Frostwork
  • »30.05.03 - 12:37
  • gfx
    gfx
    Posts: 23 from 2003/2/25
    I had many troubles compiling the XFree86 4.3,
    make World without any troubles, but make install
    failed, and now my whole X-window doesn't wanne start anymore ...
    get the new 4.3.0 version from www.xfree.org
    you'll also need the following files:
    apt-get install libncurses5-dev
    apt-get install libglpng-dev
    apt-get install libpam0g-dev
    untar the xfree source in /usr/src
    cd xc
    make World
    make install
    and don't forget to read the readme files!
    :pint:
  • »31.05.03 - 10:39
    Frostwork
    Hi, gfx!
    Thank you for reply!
    For bad luck I still don't have internet-access
    on my peggie, so I can apt-get install XXX-from internet on it!
    But soon djbmister sends me his precomiled
    XFree4.3+KDE3.1 + Debian8CD distrib
    and then all my trouble is gone....
    Bye
    Frostwork
    PS: Nice cat!
  • »31.05.03 - 11:55
    klapdeur
    Posts: 132 from 2003/6/28
    hi lowietje i've herat that you allready have mandrake running. i was visiting the amiga show in maarsen today. i bought the mandrake ppc cd there but i forgot how to run the installer in textmode of debian. what was it i have to type to start the installation ???
    greetz klapdeur
  • »28.06.03 - 20:44
