Upgrade MOS?
    Robert
    Posts: 331 from 2003/5/12
    To those who have upgraded to 1.44, I want to ask if it's much
    improved over 1.4, which is what I'm using here?
    Just trying to decide whether to bother yet.
    Robert.
  • »13.04.05 - 11:22
    aliem
    Posts: 85 from 2003/12/11
    1. Better Trace
    2. Can read DVD
    3. Many bugs resolved
    Bye
  • »13.04.05 - 13:02
    Posts: 2732 from 2003/2/24
    And a few new introduced!  :-P
    Nah, I would really recommend upgrading. Many overall improvements. :-)
  • »13.04.05 - 13:26
    Posts: 1932 from 2003/10/19
    Yup is much more stable, but as said there are are few new bugs. Radeon driver wont let you test new screen modes, to fix that I use the old driver since I couldnt see anything new with the 1.4.4 version. AHI.device needs to be replaced and a new one is out to solve the problem some had and a few other things, but they all have a work orround from what I have seen.
  • »13.04.05 - 13:38
    Posts: 2095 from 2003/6/4
    After upgradibg to 1.4.4 all my settings from 1.4.2 were still
    present. No need to edit new modes. Driver in use is Radeon 4.1beta42
    My advice: b4 upgrading check all your monitor settings and, if needed
    adjust some of them, then upgrade.
  • »13.04.05 - 15:05
    Tomo
    Posts: 94 from 2003/7/29
    After upgrading I couldn't print anymore with my Peg 1 600Mhz. I replaced therefor the new parallel-device with the old and all works nice again.
    (Printing with Studio and Pagestream 4)
    Booting is slower than with the old Ambient.
    Tom
  • »13.04.05 - 15:11
    Robert
    Thank you all for your answers.
    @Acill:
    What's the deal here?
    My main use of the Pegasos now is ProStation Audio (Yes - it works again!) and I'm very reluctant to change anything that might bugger up using PSA.
    Bear in mind that I've only just got my machine working properly again after about a month on the sidelines.
    Robert.
  • »14.04.05 - 12:30
    guruman
    Posts: 462 from 2003/7/21
    The deal is that 1.4.4 upgraded AHI.device as well, but the new version had some problems with audio streaming. An additional update of said file was then provided (within a couple of days) and you can find it on MorphOS-News (where you'll find also a link to the new AHI 6.0rc3) or download directly from here.
    Don't be afraid, I found the update quite stable and almost problem free (it has indeed solved some problems for me!).
    Kind regards,
    Andrea
  • »14.04.05 - 12:47
