Burning DVDs with MOS!
    Posts: 1084 from 2003/3/24
    To all that want at least to burn DataDVDs for buckup or such stuff. I registred TheFryingPan and i am very satisfied, TFP burnd a full DVD with 4,7GB of data on a DVD-R and on DVD-RW without problems "on the fly". So get that Software now if you want to burn DVDs under MOS without the need of Linux! :-D
  • »09.03.05 - 17:07
    SoundSquare
    Posts: 1214 from 2004/12/1
    good news !
    what about DVD+R does fryingpan handle it ?
    what is your dvdwriter brand and model ?
  • »10.03.05 - 07:09
    Kaczus
    Posts: 199 from 2003/9/6
    I don't know if newest version can burn DVD+R, older versions has some problems with it.
    Kaczus/BlaBla & AUG-Lodz Happy Pegasos User
  • »10.03.05 - 08:22
    MarK
    Posts: 641 from 2004/1/25
    Hi all,
    FryingPan had naver troubles with DVD+ media, only DVD- media was a bit problematic. The current FryingPan burns everything and pretty well. I suppose, everyone should register this cheap piece of software.
    Bye, MarK.
  • »10.03.05 - 09:46
    Posts: 34 from 2004/4/8
    We have only one question remaining now :
    The sfs when support larger files than 4GB ?
    Without these feauture we cant write dvd iso images.
    csabanw
  • »10.03.05 - 09:59
    MarK
    afaik, that's problem of OS only... I can burn 4.7 or even 8.5 gig DVDs with FryingPan on the fly, but I can access them only under linux... I hope, this 'feature' will be fixed soon.
    Bye, MarK.
    ps: I asked about these troubles quite long time ago (in time of MOS 1.3) and I was told, that it will be fixed in MOS 1.4... and guess... it wasn't.
  • »10.03.05 - 10:13
    It is working in the new DOS Api, that in MOS 1.5, but its not released to the public :P
  • »10.03.05 - 13:12
    GK_LKA
    Posts: 481 from 2004/3/28
    How fast do you write the DVD's? Does it use a lot of CPU? (Under linux I can burn DVD's at 4x speed (I have a 16x writer) with almost 0% CPU load.)
    [ GK / LKA Team ]
  • »10.03.05 - 14:00
    MarK
    I burnt a DVD 16x with about 70% (iirc) of CPU usage with Pegasos2/G4. This isn't a problem of FryingPan, but missing DMA support in MorphOS, I guess.
    Bye, MarK.
  • »10.03.05 - 14:12
    @ SoundSquare: Read my Signatur! I have a NEC ND-3500 AG DVD+/-RW 16x Drive!
    @ MarK: Why you can't read the whole DVD? I burnt one with over 4Gigs on the fly with 13 avi files and i can play them all!
  • »10.03.05 - 17:32
    MarK
    @ ThePlayer: I don't know, I can play them also, but (in MPlayer) I'm not able to move in the movie. Usualy every movie, that is placed on the end of the DVD doesn't play well (till end). And FP's structure causes, that directories are burnt after files (in root) so if You have a directory with 500 megs and then the rest of avis, those files in the directory won't work, while all the files in root will. Atleast under actual MorphOS.
    Bye, MarK.
  • »11.03.05 - 06:39
    I will try it today with a DVD-RW.
    I will post my results
  • »11.03.05 - 08:54
    I burnt a DVD with 1,6GB Backup of my SYS:Partion and the rest was filled with Avi Files. I can't even play the Avis or copy them back to my HD but the SYS backup is OK. :-(
    Now i will try to put the Avis into the SYS drawer on the DVD!
  • »11.03.05 - 10:02
    @ MarK: Now i've got it the Avi's Names are to long after rename all works ok. I can put the avis in root on the DVD or in a Folder and root on the DVD without problems.
  • »11.03.05 - 11:27
    cecilia
    Posts: 459 from 2003/8/30
    DVD faq - which some might find useful.
  • »12.03.05 - 00:33
    MarK
    With the latest FryingPan 0.4b, I burnt a DVD 16x with only about 15% CPU usage! The big amount was probably caused by debug output.
    Vivat FryingPan.
    Bye, MarK.
    PS: I will check asap the 4 gig support with new MorphOS 1.4.4 :-) Thanks MOS Team!!!
  • »29.03.05 - 07:31
    pegasosuser
    Posts: 138 from 2004/4/9
    I have register Frying Pan and working good! no problems.
    I brough a Plextor 708A +/- DVD-RW.
    TNX to Tomasz Wiszkowski.
    greetings Cor van Londen.
    PEGASOSII G4@1Ghz Registered MorphOS2.5 & AmigaOS4.1 1024DDRam ATI RADEON9250-256Mb(128Bit) Creatieve Soundblaster Live! 2 x HD MAXTOR U-ATA133 160Gb 8Mb-Cache Plextor DVDR +- RW 708A 2Mb Buffer ONLY PEGASOS MAKE IT POSSIBLE!
  • »13.04.05 - 18:29
