mos 1.4.4 cd filesystem
    klapdeur
    Posts: 132 from 2003/6/28
    hi guys is it possible to only change the cd filestystembugfix to
    replace it on 1.4.2 ??
    i had 1.4.4 installed but then i couldnt play freespace anymore
    because of some bug that it thinks its write protected. so i had to go
    back to 1.4.2 but i like to get that dvd thingie bugfix on my setup.
  • »03.04.05 - 10:34
    Posts: 1923 from 2003/10/19
    remove audio.device emulation. Thats the only thing preventing it from
    working as far as I know. Several others had the same problem and it
    worked after doing that.
  • »03.04.05 - 16:40
    Posts: 408 from 2004/7/15
    Very weird IMHO. CD drive is really read-only, so what can be wrong with write protection? :-o
    iPod, iBook, iMac,... iRobot?
  • »07.04.05 - 06:27
