Wildfire 7 MorphOS Version of the MPEG Saver and Loader
    eksec
    Posts: 7 from 2005/3/12
    Wildfire 7 MorphOS Version of the MPEG Loader and Saver available on www.wk-artworks.de
    The files are compiled to run on Pegasos with MorphOS. We can not guarantee that this programs will run on all systems.
    Tests were done on Pegasos 1 G3/600mhz.
    Saving an test animations as an MPEG file:
    68kmpegsaver: Time 1min42sec (68k test with activated JIT)
    ppcmpegsaver: Time 16sec
    Special thanks to Oliver Hummel for compiling and tests.
    If you have any questions please contact Andreas Küssner: ak@wk-artworks.de
    [ Edited by eksec on 2005/4/2 20:21 ]
  • »02.04.05 - 17:19
    Bladerunner
    Posts: 418 from 2004/2/19
    If you want to do the test yourself, Load the Picturesequence found in wf:images/Anim1/Text3D
    It is a short 30 frame anim. Then simply convert it into a mpeg anim.
    I`m very curious what a G4 is able to do here.
    BTW, with disabled JIT, It took 3min47sec...
    And thank you Andreas for the nice little Wildfire presents recently :-) Thats no matter of course.
  • »02.04.05 - 18:28
    magnetic
    Posts: 2129 from 2003/3/1
    THANK YOU THANK YOU THANK YOU
    :-D
    WF 7 is a nice app and should be still available from dealers for purchase..
    magnetic
    ps: However, maybe some more tutorials/guides would help sales or so?
  • »02.04.05 - 18:31
    Bladerunner
    Be patient young padawan ;-)
    Honestly, the best thing is to play a bit with Wildfire, as it has a real powerfull bubble help. And the short "Workshop" in the last Wildfire Topic should make a nice entry.
    Well... perhaps I am going to make a "real" workshop out of that. But then i really need someone for translation/correction ;-)
  • »02.04.05 - 18:53
    Posts: 2565 from 2003/2/24
    So Olli, when did you learn how to use a compiler ?  :-o
  • »02.04.05 - 19:04
