How to print via postscript
    zukow
    Posts: 652 from 2005/2/9
    i' ve hp 5lj with postscript module. maybe somebody know how to print #?.ps files sending it to printer?
    [sorry for my lame english ;)]
  • »02.04.05 - 14:11
    roschmyr
    Posts: 211 from 2003/2/20
    did you try Ghostscript8.5 , if not download it.
    you can find it here and an installationsguide
    http://www.whoosh777.pwp.blueyonder.co.uk/
    the easiest solution for viewing/printing/convert
    EPS/PDF files is GS8gui
    http://main.aminet.net/pub/aminet/gfx/conv/GS8gui.lha
  • »02.04.05 - 15:04
    Posts: 2562 from 2003/2/24
    @roschmyr
    You DID read the question ??
    @zukow
    Something like "copy xy.ps to par:" should do the trick.
    [ Edited by Kronos on 2005/4/2 18:22 ]
  • »02.04.05 - 15:22
    roschmyr
    @Kronos
    didn't know, that i've to read the question :-)
    i tried "copy ps-file to par:" on an old HP laser
    with PS-Modul from work, without luck
    copy ps-file to PS: works for me with installed GS from Whoosh777
  • »02.04.05 - 16:00
