More internal USB devices
    Posts: 66 from 2003/10/5
    Hi all!
    One little annoyance of PEGs is having only one
    internal USB connector (AOne has two, AAAGH!).
    I need to put an USB port on the front panel
    to use with removable devices (pens, etc.)
    since it's too boring to reach the rear of my
    Peg far under the desk. The only internal
    USB connector is already used by my internal
    multi cards reader (and please don't answer
    to buy an external one because I DON'T WANT IT!!
    Any idea ? Is there some kind of internal
    hub or such which I can use to have one or
    two extra internal USB connections ?
    Thanks!!!!
  • »31.03.05 - 15:24
    thefab
    Posts: 92 from 2003/8/19
    hum, what about an usb keyboard with usb hub integrated? ;)
  • »31.03.05 - 15:37
    >integrated? ;)
    Well, it could be a good idea but I'm in love
    with my beautiful Logitech UltraFlatX keyboard
    and wouldn't change it for nothing :)
  • »31.03.05 - 15:57
    Posts: 1520 from 2003/2/24
    AFAIK one internal USB header is used for AGP.
  • »31.03.05 - 16:03
    Robin
    Posts: 741 from 2003/2/24
    Get an usb-pci card ... one with an internal connector.
  • »31.03.05 - 16:06
    Where, what ? There's any way to use it without
    modifying the board ? And how ?
  • »31.03.05 - 16:11
    Ingo
    Posts: 103 from 2004/3/19
    Thanks!!!!
    Check this (pretty long url but works here :-o)
    http://images.google.de/imgres?imgurl=http://www.bora-computer.de/img/indexgfx/usb_hub_intern.gif&imgrefurl=http://www.bora-computer.de/index.php%3Fcmd%3Dshop%26funk%3Dkaufen%26art%3D503&h=180&w=300&sz=24&tbnid=9Lqdkh5KYMQJ:&tbnh=66&tbnw=110&start=2&prev=/images%3Fq%3Dusb%2Bhub%2Bintern%26hl%3Dde%26lr%3D
  • »31.03.05 - 16:11
    >Get an usb-pci card ... one with an internal >connector.
    Any model could work ? Would Poseidon correctly
    see and configure it ??
  • »31.03.05 - 16:13
    >check this (pretty long url but works here)
    Wow, cool :-)
  • »31.03.05 - 16:16
    Robin
    I'm sure you can get a working usb-card
    from any pegasos-dealer :-)
    I got mine from computer-city :-D
  • »31.03.05 - 16:38
    ehr... Miky ?????? =)
  • »31.03.05 - 18:32
    Some AGP cards provide a USB header. If you manage to get such card you can use fourth USB header.
  • »01.04.05 - 09:26
    Btw, Miky told me about an old MorphZone thread
    where they speak of hub chips compatibility,
    in the case I decided to buy a PCI USB card
    or just a frontal hub. Can someone point me
    on that thread please ?
  • »01.04.05 - 09:39
    guruman
    Posts: 461 from 2003/7/21
    The thread is this one (I guess):
    https://morph.zone/modules/newbb_plus/viewtopic.php?topic_id=3151&forum=11
    The chipset you should be looking for in an USB PCI card is the VIA VT6202.
    Kind regards,
    Andrea
  • »01.04.05 - 11:22
    Thanks for the precious info !
    There's only one thing I really really can't
    understand: why Pegasos designers decided to
    put the fourth USB channel in the AGP slot, thus
    making it pretty unusable ?
    I don't think there're AGP gfx cards with any
    USB fetures/connection...
  • »01.04.05 - 15:16
    BatteMan
    Posts: 288 from 2003/2/24
    I've got the solution too :
  • »02.04.05 - 08:43
