MorphOS 1.4.4 SANA2 drivers and AmiTCP/IP with startnet scri
    Piru
    Posts: 624 from 2003/2/24
    Some users have had issues with new MorphOS 1.4.4 SANA2 drivers and AmiTCP/IP with startnet script. Check that your startnet script has the following line (or something similar):
    AmiTCP:bin/online >nil: eth0
    The line should be after "ifconfig eth0".
    Technical: The new SANA2 drivers are SANA2 spec conforming and don't go online automagically.
    NOTE: eth0 is an example, obviously you need to use your specific interface name, if it's not eth0!
    [ Edited by Piru on 2005/3/28 23:36 ]
  • »28.03.05 - 09:10
    magnetic
    Posts: 2129 from 2003/3/1
    Piru
    Thanks for the post and thanks for your work on the MOS release
    :-D
    magnetic
  • »28.03.05 - 11:43
    Posts: 2732 from 2003/2/24
    @ magnetic
    Hi magnetic! Glad to see your'e alive! ;-)
  • »28.03.05 - 13:01
    Posts: 1087 from 2003/3/24
    I don't have this line "ifconfig eth0" in my startnet script, so how can i get Genesis now Auto-Online again? I tried to put "AmiTCP:bin/online >nil: eth0" in the startnet script but without success.
  • »28.03.05 - 15:51
    thefab
    Posts: 92 from 2003/8/19
    you must replace eth0 by the name of your interface name in genesis
    prefs.
    but it doesn't work either here with mos 1.4.4, the device does not
    go online, so i put back the old network device.
  • »28.03.05 - 19:06
    I have noch eth0 interface name in that startnet file! :-? With MiamiDx all works fine but Genesis is faster. And it seems that all my problems with moving large Files in my network are gone. :-)
  • »28.03.05 - 23:52
    Piru
    Ok, perhaps you guys having trouble should post your (modified) startnet script. Maybe it's just some small mistake?
  • »29.03.05 - 00:59
  • scf
    scf
    Posts: 54 from 2003/6/3
    in my startnet there is amitcp:bin/bootpconfig ....
    There was some complain in log window about some vec=1 is not supported, must be -1. It was during executing mount tcp:. So I removed it. But this didnt help - interface went offline still. So I placed amitcp:bin/online rtl0 after bootpconfig. It works now, but I have unclosable log window with contents like this: ... interface rtl0 went offline
    ... interface rtl0 is online again. Would like to know how to force this window close :)
  • »29.03.05 - 06:26
    Piru
    @scf
    No worries, you can get rid of the log window by editing AmiTCP:db/AmiTCP.config and editing/adding specific line.
    ConsoleName = "nil:"
    If the line already exists you can edit it, if it doesn't exist, add it.
    [ Edited by Piru on 2005/3/29 11:14 ]
  • »29.03.05 - 06:32
    GMKai
    Posts: 259 from 2003/4/7
    where can one find this startnet-file?
    why does genesis have an option for auto-online and why is no more supported?
  • »29.03.05 - 07:16
    Piru
    It was used with old AmiTCP/IP without GUI.
    It is no longer supported?
    AmiTCP/IP Genesis should go online just fine, if using Genesis to control the AmiTCP/IP.
  • »29.03.05 - 08:21
    Here is my Startnet script:
    .key DEBUG/S,PROVIDER/K,SCRIPT/K,NOSRV/S,BOOTPOPTIONS/F
    .bra {
    .ket }
    ; use profile made by AmiTCP Prefs by default
    .def PROVIDER "ENV:NetConfig/Provider.conf"
    ; the default dial script
    .def SCRIPT "AmiTCP:db/Dialscript"
    ; AmiTCP/IP DialUp 4.5 NetConnect version startnet script
    ; Copyright © 1996 AmiTCP/IP Group,
    ; NSDi - Network Solutions Development Inc., Finland
    ; All rights reserved.
    ; *NOTE* YOU SHOULD NOT NEED TO EDIT ANYTHING BELOW. IF YOU NEED TO START
    ; *NOTE* UTILITIES, DO IT IN THE ENV:NetConfig/User-Startnet.
    ; *NOTE* YOU CAN STOP THESE UTILITIES IN ENV:NetConfig/User-Stopnet.
    ; Set the failat level so that the errors can be handled by the script
    FailAt 21
    If NOT Exists {PROVIDER}
    Echo AmiTCP/IP is not configured
    Echo Starting the configuration tool...
    Run >nil: <nil: NetConnect:AmiTCPPrefs
    Quit 20
    EndIf
    Version bsdsocket.library >nil:
    If Warn
    If X EQ "X{DEBUG}"
    Run >nil: <nil: AmiTCP:bin/AmiTCP.kernel {DEBUG}
    Else
    Run AmiTCP:AmiTCP {DEBUG}
    EndIf
    EndIf
    AmiTCP:bin/WaitForPort AMITCP
    If NOT Warn
    ; Log in with the default user name (nobody)
    AmiTCP:bin/login -f dolphin
    ; Configure AmiTCP
    AmiTCP:bin/bootpconfig PROVIDERFILE={PROVIDER} DIALSCRIPT={SCRIPT} {DEBUG} {BOOTPOPTIONS}
    If NOT Warn
    ; Mount TCP:
    Assign TCP: Exists >NIL:
    IF Warn
    Mount TCP: from AmiTCP:devs/Inet-Mountlist
    EndIf
    ; Start inetd if needed
    If X EQ "X{NOSRV}"
    If X EQ "X{DEBUG}"
    Run <NIL: >NIL: AmiTCP:bin/inetd
    Else
    Run AmiTCP:bin/inetd {DEBUG}
    EndIf
    EndIf
    ; Start utilities in ENV:NetConfig/User-Startnet
    If Exists ENV:NetConfig/User-Startnet
    Execute ENV:NetConfig/User-Startnet
    EndIf
    ; Successfull end
    Echo AmiTCP/IP DialUp 4.5 is now on-line. Your host name is $HOSTNAME.
    Else
    Echo AmiTCP/IP DialUp configuration failed!
    EndIf
    Else
    Echo AmiTCP/IP DialUp couldn't be started!
    EndIf
    ; Ask NetConnect to reload the interface
    ; (and change the state of the start/stop button
    Rx >Nil: "address NETCONNECT; refresh"
    ; EOF
  • »29.03.05 - 10:38
  • phx
    phx
    Posts: 70 from 2005/3/29
    This is a minimal startnet-script for AmiTCP/Genesis,
    which works for me with 1.4.4:
    ---8<---
    SYS:C/RexxMast >NIL:
    AmiTCP:bin/login -f root >NIL:
    AmiTCP:bin/umask 022 >NIL:
    run >NIL: AmiTCP:kernel/AmiTCP >NIL:
    If NOT Warn
    ifconfig lo0 127.0.0.1
    ifconfig via_rhine 192.168.0.4 netmask 255.255.255.0 broadcast 192.168.0.255
    online via_rhine
    If NOT Warn
    setenv HOSTNAME `AmiTCP:bin/hostname`
    setenv HOST `AmiTCP:bin/hostname`
    route add default 192.168.0.250 >NIL:
    Else
    Echo Ethernet interface configuration failed!
    EndIf
    Else
    Echo AmiTCP couldn't be started!
    EndIf
    ---8<---
    Pegasos is at 192.168.0.4 and router at 192.168.0.250.
    Replace this to fit your needs.
  • »29.03.05 - 12:00
  • scf
    scf
    Piru thanx
  • »29.03.05 - 12:37
    Piru
    Ok, I have to correct myself, there indeed is some icky problem introduced by the 1.4.4 SANA2 drivers and Genesis.
    Genesis issues S2_ONLINE command before configuting the interface with S2_CONFIGINTERFACE, and then expects the driver to report S2EVENT_ONLINE from S2_ONEVENT.
    The current drivers don't allow S2_ONLINE before S2_CONFIGINTERFACE (the spec is perfectly clear that S2_GETSTATIONADDRESS and S2_CONFIGINTERFACE should be the very first commands to send).
    Anyway, the end result is that Genesis doesn't go online even if auto online is enabled. This can be worked around by doing manual Quote:
    (replace eth0 with your interface name) few seconds *after* starting Genesis.
    Another option is to downgrade the drivers.
    I'm truly sorry for the trouble this has caused. I partly blame the very confusing SANA2 specification: It's a bit too vague at places...
    [ Edited by Piru on 2005/3/30 11:05 ]
  • »29.03.05 - 16:30
