Posts: 408 from 2004/7/15
First of all, Amiga documentation for Samba says that nmbd should be run from inetd. This is PLAIN WRONG!!!
Just run nmbd as "Run >NIL: nmbd -F". This is mandatory because nmbd is responsible not only for resolving your name but also for registering you on the network. If nmbd starts and stops on every request it will bug your network (read more in the docs about browsing, master browsers and how all this crap works in order to understand the whole problem).
When you get nmbd working, try "nmblookup <your name>". If it responds, everything is fine. Try to connect.
iPod, iBook, iMac,... iRobot?
