PAPYRUS OFFICE
    Posts: 18 from 2005/1/27
    Short and simple: Is it worth the 120€? I need some (rather) serious work to be done and I'm getting crazy with all this changing from my peg to THE THING.
    Thanks.
  • »09.03.05 - 21:20
    analogkid
    Posts: 711 from 2004/11/3
    I think it works ok now, but it's far from being perfect.
  • »09.03.05 - 21:27
    Velcro_SP
    Posts: 929 from 2003/7/13
    I like it and it does a lot of stuff.
    Pegasos2 G3, 512 megs RAM
  • »09.03.05 - 23:00
    poundsmack
    Posts: 1346 from 2003/6/7
    works for me...though importing of certian kinds of file formats is not always perfect
    "Poundsmack, official morphzone thread creator" -LorD
    "Wanna be lord of the avatars." -JKD
  • »10.03.05 - 00:38
    Otti
    Posts: 20 from 2004/3/31
    I am very surprised about a lot of things never seen an a Amiga.
    It works fine. There are a lot of very useful funktions.
    Ok there some little bugs, but they are really little.
    You will not repent it, if you bought it.
    By the way
    Otti
  • »10.03.05 - 07:42
    DedyAmigo
    Posts: 41 from 2003/7/19
    Hi Poundsmack,
    can you tell us, something about compatibility
    with MS(heet)Works?
    Thx,
    Dedy
    http://amigo.bodli.net
    Powerbook G4/1.67GHz, MOS 3.17 reg
    Asus Zenbook UX32VD, Xubuntu 20.04
  • »10.03.05 - 13:42
    discreetfx
    Posts: 400 from 2003/7/26
    How does the spreadsheet in PAPYRUS OFFICE compair to Turbocalc 5.0 for Amiga OS?
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »11.03.05 - 04:33
    MacFly
    Posts: 37 from 2003/10/14
    Papyrus has powerfull spreadsheet functions from simple invoice to complex accounting everything is possible. Integration into Papyrus Word is very easy to do simply create a textframe and click on speardsheet icon to customize it for your needs.
  • »11.03.05 - 11:36
    discreetfx
    MacFly since your here can I ask when Burn It Pro will be out, the version that burns DVDs. Sory for being OT but that is something I would buy right now.
    [ Edited by discreetfx on 2005/3/12 13:31 ]
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »12.03.05 - 04:39
    Ingo
    Posts: 103 from 2004/3/19
    i'd like to know that too.
  • »12.03.05 - 07:10
    MacFly
    the problem is the register tool for BurnIT coder is to busy with another project and has not found time to finish Burnit . I hope that we will get a release version until 3. Quarter 2005
  • »12.03.05 - 17:48
    Posts: 1932 from 2003/10/19
    Thats a long way off, what a shame. Maybe someone else can help you
    with the project?
  • »12.03.05 - 18:08
    MacFly
    thats true Im also unhappy with that situation, BurnIT is finished since months only the register tool not.
    May be some email feedback to the coder will speed up his work  :-D .
    You can reach him under ms at burnit dot info
  • »13.03.05 - 18:53
  • rms
    rms
    Posts: 606 from 2004/11/27
    @ Titan
    OK but is it possible to import/open Excel files?
    We receive a lot of such files from our customers and have to extract data for further processing from them.
  • »15.03.05 - 05:22
    MacFly
    You can import/export Excel CSV Files also dBase (.dbf) or plain CSV files
  • »15.03.05 - 09:14
  • rms
    rms
    @ Titan
    but no .xls files? We cant ask our customer to do a "save as" and then select .csv, as most of thouse windows user dont even know that it is possible to save as something else...
    In fact it would be great to have the possiblility to, at least, import .xls files as we cant get around this because so many people are using it!
  • »15.03.05 - 10:59
    SoundSquare
    Posts: 1214 from 2004/12/1
    importing .xls files is a key feature and should be implemented if possible.
    I'd definately buy it then
    could someone post some decent screenshots ?
  • »15.03.05 - 11:34
