TinyGL Libraries with Includes (needed for PowerSDL)
    aliem
    Posts: 85 from 2003/12/11
    Tonight I was trying to compile a simple SDL program with PowerSDL ... but ...
    can't find tgl/gl.h tgl/glu.h and proto/tinygl.h
    I tryed to install the TinyGL.lha archive found in www.morphos-news.de but the problem persists (I renamed GL to tgl in includes) for proto/tinygl.h
    Where can I find it?
  • »09.03.05 - 10:28
    null
    Posts: 18 from 2005/2/10
    Had same problem, but, if you dont need OpenGL for compiling this example you can just comment the header where the opengl part of SDL is included, i think its SDL.H, dont remember exactly though and since im at work i cant help you futher, though its easy to find out.
  • »09.03.05 - 10:38
    aliem
    mmm i'll do it ... but could be great to have tgl includes ... many many other games portable :(
    ByE
  • »09.03.05 - 11:14
    liquidbit
    Posts: 407 from 2003/10/12
    look here:
    http://sdl.innoidea.hu/
    and ask Kiero for the latest tinygl.library
  • »09.03.05 - 13:46
