DOSBox sound
    MarK
    Posts: 641 from 2004/1/25
    Hi all!
    I love the dosbox emulator, it worked pretty well. Now it works, but there is no sound output. I don't know, how to set it up to get the sound. I played Dune2 and there were sounds, now it's silent. Please help, playing without sound is really very boring... btw: there are over 2 gigs of dosbox games on abandonia.
    Bye, MarK.
  • »07.03.05 - 07:37
    Falcon_11
    Posts: 33 from 2004/2/7
    Sorry, but I don“t know English.
    Cau Marku.
    Teraz som v praci a preto to nemozem odskusat, ale urcite je v Dune2 nejaky setup subor na nastavenie zvuku, mozno siete atd...
    DosBox emuluje 2 zvukove karty a to Soundblaster a kompatibilne a Ultrasound. Mas to uvedene ked startujes DosBox. No a v tom setup subore musis nastavit pozadovanu kartu a nastavit jej Adresu, IRQ-prerusenie a DMA pristup. Napr: Soundblaster 220, 5, 1 . Ked pridem domov, tak to skusim a potom by som ti to napisal presne.
    Ked sa ti bude chciet, tak toto co som pisal mozes prelozit, aby aj ostatny vedeli, keby mali problemy..
    Bye.
    DEAD
    MB :Pegasos-II
    CPU :G4/1GHz
    OS :MOS 2.2 reg, MOS 1.4.5, Ubuntu 8.04, MACOSX Panther on MOLk
    RAM :512MB-DDR266 Apacer
    GFX :ATI-Radeon 9200 128MB
    HDD :MAXTOR-160+80GB ATA133
    TV :Pinnacle Studio PCTV
    Powerbook G4 A1139, MOS3.19
  • »07.03.05 - 15:40
    mcbarlo
    Posts: 31 from 2003/11/8
    You probably have installed new powersdl.library. I don't know why it can't open ahi.device. I have two solutions:
    1. Downgrade your powersdl.
    2. Turn on somthing what plays sound for example ANR and while it is playing run DOSBox. After you can turn off ANR and sound will be work in DOSBox. I think. ;)
  • »07.03.05 - 17:34
    Posts: 1520 from 2003/2/24
    Oh.. that is interesting (#2). PowerSDL leaves only few signal bits free (in case of DosBox) and it seems starting AHI needs few signal bits temporarily. I managed to reproduce no sound problem here so maybe I can try fixing psdl too...
  • »07.03.05 - 18:22
