Mldonkey trouble
    maurensen
    Posts: 358 from 2003/10/3
    I have a problem using mldonkey. When I start a search query with 's' command
    I can see tons of results with 'vr' but when I try to downolad something with
    'd <num>' command, a blank file is created in the temp directory of mldonkey
    but nothing is downloaded, with 'vd' command I see always 0% completed also
    after waiting several minutes ang also changing the file to download.
    I think my config is ok: adsl connection, latest mldonkey mos release, Mos SDK
    installed & telnet via sh, servers.ini copied from bonus dir...
    Any suggestions? thanx in advance.
  • »01.03.05 - 13:21
    Posts: 1087 from 2003/3/24
    You have to be more patient MLDonkey is not the fastest P2P Software. It can take hours till a download starts.
  • »01.03.05 - 15:20
    maurensen
    10x 4 the replay. I hope the only problem is my little patience. I'll
    retry!
  • »01.03.05 - 17:31
    maurensen
    :-( Bah, I've been connected 4 over 1 hour but the vd command gives me
    always 0% of dowload completed on all the various files i've selected!
    I'm so unluky to find all servers so busy??
    Any other suggestions?
  • »01.03.05 - 18:14
    I don't know what you try to downlaod but sometimes when the Stuff is not so popular it can take a day or two!
  • »01.03.05 - 18:48
    Jupp3
    Posts: 1193 from 2003/2/24
    Check the "Active" numbers for a file. The bigger number, the more likely you'll get it faster...
    Also downloads will be slower if you don't share anything (which is likely the case when you just started using the program)
  • »02.03.05 - 09:09
    Posts: 261 from 2003/3/13
    I got the solution for you,
    everything can be solved,
    no more problems, no more struggle's,
    no more HD crashes, no more pain,
    use Linux! :-P
  • »02.03.05 - 18:43
    guruman
    Posts: 462 from 2003/7/21
    Felix, I take this as a sign you won't be upgrading your mlgui anytime soon... :-D (yes, I know you halted your MorphOS development until there is support for 3D acceleration for Radeons, but I'm still hoping you will resume also this nice one when you'll return using MOS).
    Kind regards,
    Andrea
  • »03.03.05 - 09:07
    maurensen
    @Felix
    Have you seen my avatar?
    Do you think I've bought a peg to run an un*x distro?  :-P  :-D
  • »03.03.05 - 11:44
    @Guruman
    Indeed, everything has stopped for me...
    I'm to drunk everynight anyway to make something usefull on bloody MOS :P
    @Maurenssen
    Who cares where you bought it for,
    On linux you can use xmule, amule, mld,torrent etc...
    And it works like a charm, don't see that on MOS... hehe
    @ThePlayer
    Not true.... downloads even with little pll on it are going
    fast end start directhly.. well again..on linux.. :P
  • »03.03.05 - 13:41
    Sphinx_Ra
    Posts: 276 from 2003/3/14
    Felix wrote:
    @Guruman
    @Maurenssen
    @ThePlayer
    Felix, yesterday you told me you where
    working on secret stuff for MorphOS.
    I know you stopped drinking, so you lie,
    i drink, look at my belly :)
    But i must agree, linux is very usefull.
    And Felix you are the best coder i know.
  • »03.03.05 - 16:11
    Posts: 918 from 2004/1/24
    @Felix
    Hehe, come on man, Dutch pride! Still have that A4000 lying around; tradi it for a working MLDonkey GUI? :-P
    @Sphinx
    /me misses your Q2 server :-)
  • »03.03.05 - 16:26
    Stevo wrote:
    @Felix
    @Sphinx
    Sure Stevo, ill create a version only for you! :P
    But to be honnest, i might look into it someday, keep your a4000 ! :)
    Yeah Spinx put up your server again, are you affraid i will kill you again ?? :)
  • »03.03.05 - 19:12
    :-D
  • »03.03.05 - 21:06
