Best LHA front end for MorphOS
    discreetfx
    Posts: 400 from 2003/7/26
    What is the best LHA/LZX GUI for MorphOS guys? Is there a native one?
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »26.02.05 - 06:21
    hooligan
    Posts: 1948 from 2003/2/23
    Yes, Shell. And it's MorphOS native ;-)
  • »26.02.05 - 06:28
    discreetfx
    I already knew that!
    Looking for a GUI so I can pointy and clicky. Oh, and Amiga OS 4.0 has a GUI based unarchiving util built in! So did 3.9.
     :-D
    [ Edited by discreetfx on 2005/2/26 10:36 ]
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »26.02.05 - 06:35
    Posts: 2514 from 2003/2/24
    Try VoodooX (works on (allmost) all archive-formats).
  • »26.02.05 - 06:53
    hooligan
    Magellan. Enough frontend for you? Drag and drop.
  • »26.02.05 - 07:35
    Kaczus
    Posts: 199 from 2003/9/6
    I use DOpus Magellan - the best front :) Unfortunately it is not
    native :(
    Kaczus/BlaBla & AUG-Lodz Happy Pegasos User
  • »26.02.05 - 07:38
    discreetfx
    Is VoodooX mos native?
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »26.02.05 - 08:05
    Jupp3
    Posts: 1193 from 2003/2/24
    Does it really matter, as it's only interface?
    But sadly, not all of the decompression libraries it uses are available MOS native...
    But I wouldn't call it "too slow" in any way - the only problem is it can't unarchive new RAR archives.
  • »26.02.05 - 08:54
    cecilia
    Posts: 459 from 2003/8/30
    VoodooX can do zip files - i've tried. works fine. while i generally use magellan, sometimes when i'm having a few problems with that method, i try VoodooX.
    and it's a nice interface. yeah, very pointy, very clicky! :-P
  • »27.02.05 - 00:45
    Schlonz
    Posts: 131 from 2004/4/16
    VoodooX is only an unarchive GUI, right? If you want a GUI für LHA,LZX,ZIP and others which does archiving and unarchiving try MiraWirArc from Aminet. Its not as nice as VoodooX and I dont know if it supports drag & drop, but its far better than shell.
    And no, its not MOS native, but who cares... its only a front-end, the CPU hungy stuff is done by the packers which you can use in MOS native versions if available.
  • »27.02.05 - 09:27
    Brumiga
    Posts: 268 from 2004/4/3
    Hello,
    There is also another tool to pack/unpack. It is X-Arc, it was released by Vapor in 1999. But it is now to old, his gui is to old and it does not offer a lot of packing methods, the choices are limited for actual use. Could it be possible to rewrite it ppc native with a gui uptodate and more efficiency in packing methods ?
    Brumiga
  • »27.02.05 - 13:24
    discreetfx
    Guys where do I download VoodooX? It is not on Aminet
    DiscreetFX
    Making your
    Digital Films
    More Effective!
  • »27.02.05 - 13:48
    tokai
    Posts: 1289 from 2003/2/25
    the best interface is muicon, no? ;)
    start MUICON and type for extracting:
    lha x blah.lha ram:
    and for archiving:
    lha a -r blah.lha blahdir
    whats so difficult with that? :)
    if you're too lazy to unarchive yourself I would suggest to use voodoo-x and xad. (also supports a lot other archivers).
  • »27.02.05 - 13:52
    Robin
    Posts: 741 from 2003/2/24
    @discreetfx
    It's not ? http://my.morphosi.net/?modul=aminet&find=voodoo+x+arc ;-)
  • »27.02.05 - 14:10
    pixie
    Posts: 148 from 2003/9/5
    Have anyone seen Peperoni working!? It's as simple as it can go... and quite powerfull too! It uses app icons, and it's a charm to use, using native ppc morphos apps (lha, arc, zip,...) it can be as fast as if it was indeed native as Peperoni itself is nothing more then a front end to those compressors... meaning, it's not MorphOS native, but quite!  :-D
    pixie - writing from a paradise called Portugal
  • »01.03.05 - 13:24
