The Shell
  • Targhan
    Posts: 2833 from 2003/2/8
    It may sound silly, but I would like to be able to boot to the shell prompt. Also, I would like to do it without having to insert a cd or messing up the startup-sequence. Is there a tool usable with MorphOS that can launch an alternate user-startup while holding a button (mouse or otherwise) during the boot sequence? Something that will escape before loadwb?
    :idea:Targhan
  • »21.06.03 - 06:03
    hooligan
    Posts: 1948 from 2003/2/23
    I think I have suggested this in b2 mailinglist.. or then I have forgotten..
    anyway
    - Holding left mousebutton = open up a shell
    - Holding right mousebutton = bypass WBStartup
    I once had a program not working in wbstartup... the only way to remove it was by booting from cd and then delete the file. Not so pro ..
  • »21.06.03 - 12:21
