Linux Lunar Lander.
    matt3
    Posts: 785 from 2004/2/10
    I thought a while ago there was a port of Linux Lunar Lander to MOS. I went to Morphosnews and the link was dead. Does the port exist?
    Matt
  • »23.02.05 - 20:10
    Posts: 12572 from 2003/5/22
    LLL 1.4 was available on Louise's SDL site.
  • »25.02.05 - 09:06
    matt3
    The site is now closed. Does anyone have archive handy to upload?
    Matt
  • »25.02.05 - 12:38
    aliem
    Posts: 85 from 2003/12/11
    I think it is not so hard to port it ... I'll try to make a makefile tonight :)
    There are only 3 C codeFiles
    try with:
    Quick Makefile
    CC=gcc
    CFLAGS = $(shell sdl-config --cflags) -Wall -noixemul
    OBJECTS= SFont.o
    LLL: $(OBJECTS) LLL.o
    $(CC) $(CFLAGS) -o LLL $(OBJECTS) LLL.o $(LIBS)
    @echo "The executable is called LLL"
    if it doesn't works try deleting Code:
    I don't know if it works.
    Bye
  • »25.02.05 - 19:02
