FlexCat for MorphOS
    Posts: 408 from 2004/7/15
    Where can i get a port of FlexCat for MorphOS? ShdW gave me an executable but i'd like to have full archive. Or it's not public?
    P.S. I almost finished my own port of FlexCat. Is this work really needed or i can erase it?
    iPod, iBook, iMac,... iRobot?
  • »02.02.05 - 04:46
    Posts: 2728 from 2003/2/24
    I have no idea but I have now spent some time searching for it, and if a MorphOS native version really exists, it's not very easy to find. The only thing I found was the sourceforge site as well as a lot of old Amiga versions. If you are close to releasing your own MorphOS version then I really think you should finish it up and release it, just to make it more easily found if for nothing else. Uploading it here to morphzone (and other places?) would perhaps be an idea?
  • »02.02.05 - 06:01
    Posts: 126 from 2003/2/17
    @sonic
    If you got this versino fro shdw, it's probably the one I did..
    so 2 thing so say : this port is working but ther's some problems with error output.... (you can get some "strange" error messages in case of errors in your .CD or .CT files, that's why it was not released publically
    secondly, 68K version works quite fine, so it's not really needed to do a ppc one, that's why I did that to learn a bit programming... but now I spend more time on localisation than coding, so I'll try to fix that when I'll have some free time.
  • »02.02.05 - 09:20
    Can you describe a bug and how to reproduce it (probably give me a file which causes it)? I'll check this out. I am going to finish and release the port soon.
    I just like native tools. I would become a famous porter (i also think about Term 4.8 and Directory Opus4) but i have absolutely no time.  :-(
    [ Edited by Sonic on 2005/2/2 16:06 ]
  • »02.02.05 - 11:02
    Just want to notice that i found the bug. It was actually not a bug but non-portable ShowError() function which expected varargs to be on the stack.
    Also i found a project on SourceForge, they continue to develop FlexCat and have more recent version of it. I sent them a letter asking to join me to the project so my changes will be merged to mainstream.
  • »21.02.05 - 07:21
    Posts: 916 from 2004/1/24
    And indeed a big thank you to Sonic for FlexCat; get it here:
    https://morph.zone/modules/mydownloads/singlefile.php?lid=252
  • »21.02.05 - 07:36
