how to extract: AWeb_3.5.05_MorphOS.tar.bz2.tar?
    pegasosuser
    Posts: 138 from 2004/4/9
    Hi al,
    I can't not extract AWeb_3.5.05_MorphOS.tar.bz2.tar
    how working that I have tar in the C
    who can me helping?
    TNX!
    Cor van Londen.
    PEGASOSII G4@1Ghz Registered MorphOS2.5 & AmigaOS4.1 1024DDRam ATI RADEON9250-256Mb(128Bit) Creatieve Soundblaster Live! 2 x HD MAXTOR U-ATA133 160Gb 8Mb-Cache Plextor DVDR +- RW 708A 2Mb Buffer ONLY PEGASOS MAKE IT POSSIBLE!
  • »13.02.05 - 12:22
    Posts: 1087 from 2003/3/24
    Get Voodoo-X and the latest XAD Librarys!
  • »13.02.05 - 12:24
    pegasosuser
    TNX! I do it
    Greetings Cor van Londen.
  • »13.02.05 - 12:33
    hooligan
    Posts: 1948 from 2003/2/23
    First use UnTar, and then BZip2.
  • »13.02.05 - 12:42
    aliem
    Posts: 85 from 2003/12/11
    First:
    rename AWeb_3.5.05_MorphOS.tar.bz2.tar AWeb_3.5.05_MorphOS.tar.bz2
    than:
    bunzip2 -c AWeb_3.5.05_MorphOS.tar.bz2 | tar xvf -
    Bye
  • »14.02.05 - 08:01
    Posts: 1932 from 2003/10/19
    I havent been able to get Aweb to start yet. I start to see the aweb logo for a quick flash and thats it. Whats needed to make it run?
  • »14.02.05 - 10:53
    pegasosuser
    I have done that and working good!
    what you need for a good working AWeb?
    that are the fonts, via Snoopium You can find the missing font.
  • »14.02.05 - 11:15
    Posts: 1521 from 2003/2/24
    AWeb needs Courier.font and Times.font but they are not in the default MorphOS setup. Run AwebCfg and change AWeb to use other fonts (i.e. Times New Roman and XCourier).
    I have private AWeb build which defaults to Times New Roman and XCourier but AWebCfg is way to go.
  • »15.02.05 - 06:16
