It's alive! (MorphOS development continues....)
    XzIt
    Posts: 250 from 2005/1/19
    Using my peggy at a daily basis i would have to say, MorphOS Lives!
    Fuck that windows shit.:D
    XzIt oF Apathy
  • »09.02.05 - 23:38
    Aaron
    Posts: 127 from 2003/6/14
    WB-Startup doesnt work
    Setting the DONOTWAIT tooltype will fix the WBStartup problem for any
    programs that accept the tooltype. CPU Monitor, Statline, and Pegasos
    Mixer start just fine after I checked the tooltypes.
    --Aaron
    --Aaron Diezman
  • »10.02.05 - 04:40
    Posts: 1932 from 2003/10/19
    strange thing here. I booted with a CD and tried to restore the MOSSYS
    dir with my backup from another CD. It looks like everything tansfers
    okay, but when I rebot the new ambient is still active. Can someone
    tell me what to do so I can replace the older ambient?
  • »10.02.05 - 10:51
    Robin
    Posts: 741 from 2003/2/24
    @Acill
    Replace
    -MOSSYS:Ambient/#?
    -MOSSYS:Libs/workbench.library
    -MOSSYS:LIBS/icon.library
    That should bring back old status.
  • »10.02.05 - 13:39
    DSLCC
    Posts: 246 from 2003/5/14
    Jonny_Rico wrote:
    Ambient just got an update to 1.41... see http://zapek.com/software/ambient/ 'cauz of the donations... so go on... send more money = new update of Ambient...
    I cannot in good conscience send any money to Zapek until he removes morphos.net and removes the hate messages from his archive. I also recommend that people do not purchase from vapor.com as Zapek is listed as a programmer there. This message is not designed to be a bad message, just a warning of the attitude that you are agreeing with when you donate money. It would be easy for Zapek to remedy this and make even more money from Ambient. 8-)
    Pegasos 1 G3 MorphOS 1.4.5* Mac G4 Sawtooth 1Ghz Tiger 10.4.1* Both Rock! :-D
  • »10.02.05 - 14:01
    SoundSquare
    Posts: 1214 from 2004/12/1
    @DSLCC
    i recommend you don't use this archive and don't even open it. I also recommend you stop using ambient.
  • »10.02.05 - 14:44
    zukow
    Posts: 662 from 2005/2/9
    wow audio.device for morphos is now available, see ann.lu - unmoderated
  • »10.02.05 - 14:48
    DSLCC
    Thanks for your recommendation. As a MOS user, I will of course continue running Ambient. I will use new Ambient releases as they come out as long as they are GPL, and maybe one day they will be usable. I will not donate money though as long as morphos.net remains online and the hate messages remain in the archives 'readme' file. 'I just cannot morally do that'... :-)
    don't even open it.
    Are you suggesting a 'hate-based' shrinkwrap license. That would be a departure from GPL.
    [ Edited by DSLCC on 2005/2/10 3:22 ] :-D
    [ Edited by DSLCC on 2005/2/10 3:25 ]
  • »10.02.05 - 15:16
