faster ibrowse load
    catohagen
    Posts: 297 from 2003/5/20
    Anyone have some tips on how to get Ibrowse loading faster, now it takes 7-10 secs and i have
    tried making the executable resident, diskcache to off, but it takes same 7-10 secs to load ?
  • »16.01.05 - 12:21
    GK_LKA
    Posts: 481 from 2004/3/28
    I had the same problem. The solution: try to delete cache, and set a small size (for me it's 20MB). Now IB loads at me around 2-4 secs (including it's own MUI screens background loading).
    [ GK / LKA Team ]
  • »16.01.05 - 12:37
    Posts: 1087 from 2003/3/24
    Reinstall IBrowse i had the same problem after some month of use IB needed up to 10sec. to start but after new install it loads fast as hell.
  • »16.01.05 - 12:38
    Posts: 1932 from 2003/10/19
    Can you do a real install? The included script does not work on MorphOS. I just extract and run from the folder the archive creates. If you can install that may be the cause of the lock up problems I have with it on many sites.
  • »16.01.05 - 13:17
    It wont couse of the MUI Path, just make a fake MUI assign to ram: in the user-startup for the installation.
  • »16.01.05 - 13:43
    Brumiga
    Posts: 276 from 2004/4/3
    Good evening guys,
    I do not remember how i installed IBrowse but since the begining it loads very fast, 1/2 or 1 second on my Pegasos 2 G4. And i have set a cache size of 100 mo, but it does not fill more than 2 or 3 % as i empty it after each session.
    Brumiga
  • »16.01.05 - 16:37
    Posts: 1521 from 2003/2/24
    It could be GlobalHistory which contains visited links. Parsing 10MB file takes a while... Delete this file or adjust link history settings.
  • »17.01.05 - 11:27
    Ingo
    Posts: 103 from 2004/3/19
    uhm!
    First of all you don't add anything to your user-startup.
    If you want to make an assign make it in the shell!
    You don't need an assign and get all installer-scripts, which ask for
    MUI: working, by simply replacing the MUI: path in the script with
    libs:mui/
  • »17.01.05 - 19:29
    Robin
    Posts: 741 from 2003/2/24
  • »17.01.05 - 21:44
