SteamDraw 0.4, 2D-Vector-GFX for MorphOS
    Posts: 2581 from 2003/2/24
    http://skleinheinrich.bei.t-online.de/
    Yes I've seen the spelling mistkes, but fixing those would require updating index.html, which is quite a pain with t-offline  ;-)
    [ Edited by Kronos on 2005/1/16 19:11 ]
  • »16.01.05 - 16:11
    Krashan
    Posts: 1107 from 2003/6/11
    Hangs the whole system at startup (just after opening tool windows). Even ramdebuglog is frozen.
  • »17.01.05 - 07:15
    liquidbit
    Posts: 408 from 2003/10/12
    Nice work... with their source you can make angels on C.
  • »17.01.05 - 07:43
    @Krashan
    Just tested with the laptop hanging on serial.
    Not a single bleep while starting (but quite a lot when I tried to select an object with the edit-tool  :-x ).
    I even removed the steam: assign to make sure.
    My guesses (and guesses is all they are):
    -You got weird MUI-settings
    -You use a patch to force SMART-REFRESH
    -You use another tool that isn't clean and SteamDraw was just enough to make it tip
    -You somehow managed to corrupt the exe while downloading/unpacking
    -Faulty RAM
    As I wrote, SD does hit within the edit-tool, and there also still seems to be a problem when changing MUI-settings, but none of these should have an effect on startup.
    @Liquidbit
    WTF ?
  • »17.01.05 - 12:12
    liquidbit
    @Kronos
    ..im talking about the demos..
  • »17.01.05 - 15:02
    @liquidbit
    "Demos" ???? One of us is in the wrong movie.....
  • »17.01.05 - 15:44
    stefkos
    Posts: 102 from 2004/2/4
    nice work, thx
  • »17.01.05 - 20:35
