Posts: 481 from 2004/3/28
Yes. You should copy env:sys/def_disk.info to drive:disk.info, and then snapshot it.
Note: You can also snapshot the window sizes of drives windows itself, but the disk.info is only reloaded at next boot, so if you set window size, snapshot it, close and reopen window it will appear in the original, unsaved size.
[ GK / LKA Team ]
