Best TV tuner PCI card for my PEGII under MOS
    Tcheko
    Posts: 544 from 2003/2/25
    Hello,
    Which TV tuner PCI card should I buy to watch TV on my pegasos II with MoS?
    Which software can I use?
    Troubles, problems with the solution?
    I have a Voodoo3 3000 AGP.
    Czek.
  • »10.01.05 - 08:37
    serge
    Posts: 725 from 2003/2/20
    I tryed succes fully a haupauge wintvGO in PAL throught the video input mode.
    On PEG I with Voodoo3 3000 PCI GFX Card
    The software used was visionary.
    Never worked with an AGP card on PEG I. This is only a PEG I probleme because of articia.
  • »10.01.05 - 12:43
    Jupp3
    Posts: 1193 from 2003/2/24
    I have some wintv card too...
    But long ago I heard that there are wintv cards with 2 different chipsets, compatible one and incompatible one...
    Better make sure you can return the card, if it doesn't work!
  • »10.01.05 - 14:58
    MarK
    Posts: 641 from 2004/1/25
    I have working Typhoon TV card with BT878 (or so) chipset...
    Bye, MarK.
  • »11.01.05 - 10:18
    Frostwork
    Posts: 302 from 2003/4/18
    I have a Terra TValue (with BT878 chipset, too) working
    and a Hauppauge PVR 350 NOT working....
  • »11.01.05 - 10:57
    Toto
    Posts: 268 from 2003/4/20
    I've got a Lifetec LT9415 wich works well with Amithlon tv and Visionary and I can use the radio tuner with RadioX.
    I've tried two different Hauppage Wintv cards but they didn't work.
    One thing that bothers me about Amithlon tv is the ugly yellow border when I watch tv fullscreen.
    -toto
  • »11.01.05 - 11:28
    Posts: 20 from 2004/2/26
    I'm started to wrote my own programm for capture video on Pegasos with bt8x8 pci cards. Now it can
    capture colored PAL/SECAM video. You can watch frame capture examples on english or russian page.
    And download latest version.
    [ Edited by _4afc_ on 2005/1/13 8:00 ]
    Autor of the BTR_8x8 - Video Capture program for MOS/QNX4/Windows.
  • »11.01.05 - 22:57
    magnetic
    Posts: 2129 from 2003/3/1
    Wow! That is excellent. Thank you so much. Can you please provide more technical details of the program. i.e its capabilities? Does it capture to HD? Does it work for NTSC? What cards have been tested? etc etc
    magnetic
  • »11.01.05 - 23:06
    Posts: 408 from 2004/7/15
    Beware of these cards! My one doesn't work on MorphOS. AmithlonTV can't tune at all and Visionary produces only b&w picture without sound. RadioX also doesn't play anything and can't find any station. Currently i use the card in Linux only.
    In addition, its receiver is a CRAP. It's terribly weak. It even can't capture all channels which my TV set shows (TV and Peg are connected to the same antenna).
    iPod, iBook, iMac,... iRobot?
  • »12.01.05 - 04:26
    Posts: 5 from 2004/4/16
    I am using a WinTV-Go with BT878. Works perfect with AmithlonTV.
  • »12.01.05 - 10:32
    magnetic
    Sonic
    Err. what are you saying? Bt8x8 cards are the MOST compatible on peg with MOS and linux..
    magnetic
  • »12.01.05 - 14:33
    Velcro_SP
    Posts: 929 from 2003/7/13
    [ Edited by Velcro_SP 20.09.2011 - 21:11 ]
    Pegasos2 G3, 512 megs RAM
  • »12.01.05 - 19:56
    The BTR_8x8 is a program for PCI video capture cards using the Bt8x8 family of video decoder chips. The project was begun 13.12.04. In which I has used my two years' back experience of writing the similar program under QNX4.
    It's not problem, but I not yet wrote this bit of code. The problem is in absent GUI for starting capture or configure format of saved file.
    After selling my Amiga I lost NTSC source for test this mode, but I will add all standarts in next versions. Now program just understand PAL/SECAM B/D/G/H/I without sound.
    I have just FlyVideo EZ'98 for testing.
    My betatesters with AverMedia still not reply me about they results.
  • »12.01.05 - 21:26
    AmithlonTV dosn't work with my FlyVideoEZ.
    Maybe because it don't have TV-tuner.
  • »12.01.05 - 21:33
    Yes, AVerTVStudio is built on BT878. But it doesn't work. Probably B&W picture is a result of using SECAM instead of PAL. But sound is still a problem.
  • »13.01.05 - 04:15
