Date and Time for MOS
    Posts: 159 from 2003/10/24
    My date and time keep resetting every time I boot MOS. I know this
    has come up before I just can't find the fix. I don't recall what has
    to be done to allow it to keep the same date.
    --Mithalas
  • »08.01.05 - 17:38
    Spidey
    Posts: 568 from 2003/2/24
    Hi Mithalas,
    In the User-Startup you place:
    Setclock load
    After the assigns.
    I have to say I don't use it anymore, perhaps it was fixed with the last update (1.4.2)?
    Bye,
    Spidey
  • »08.01.05 - 19:46
    Posts: 2728 from 2003/2/24
    Yes, this has been fixed since a very long time now. Someone needs to
    do some updating! ;-)
  • »09.01.05 - 09:07
    magnetic
    Posts: 2129 from 2003/3/1
    Yes, this has been fixed for some time... you need a better boot.img AFAIK
    magnetic
  • »09.01.05 - 18:27
    Posts: 98 from 2004/6/4
    It is NOT fixed completely in 1.4.2 AFAIK. The problem is that after booting Debian MOS clock drops down to 1999. The time and day are stayed correct, but year is 1999. And this glitch is quite disturbing.
    WBR, Vladimir Berezenko
  • »10.01.05 - 04:51
    Falcon_11
    Posts: 35 from 2004/2/7
    Yes, you have right. I have the same problem with clock Linux --> MOS. Maybe , when come MOS 1.5, will this bug fixed.
    Sorry for my bad English.
    DEAD
    Pegasos-II
    Powerbook G4 A1139, MOS3.19
  • »10.01.05 - 06:27
    SoundSquare
    Posts: 1214 from 2004/12/1
    to fix that u have to disable the GMT synchronization during the Debian installation. When it asks u if your clock is GMT compliant just select "NO"
    it can be done after the installation but i don"t know how.
  • »10.01.05 - 08:21
    Thanks Spidey just what the doctor ordered.
    Some people may not have problems with it under 1.4.2 but I do. My date drops back to 1999 on every boot.
    --Mithalas
  • »10.01.05 - 14:55
