*BSD Porting Status
    cecilia
    Posts: 459 from 2003/8/30
    roschmyr wrote:
    @cecilia
    disable the tooltype FULLSCREEN in ShowGirls
    I did that but after investigating the files - using DOPUS (love that program!) - I discovered that I had multiple MUI pref files for ShowGirls. they were fighting each other, apparently :-P
    so I deleted all of them, started the program up again and saved my new prefs.
    works beautifully!
    Thank you, thank you!
  • »28.11.04 - 15:33
    Jacks
    Posts: 5 from 2004/8/29
    Ancil ...do you have , or did you build a Peg2G4? ..thinking about doing just that ?
    Jacks ..lonnie_10@sbcglobal.net
    from Morro Bay , Calif.
  • »09.01.05 - 01:46
