MAME with USB-Joystick
    GMKai
    Posts: 259 from 2003/4/7
    I have an USB-Joystick I want to use with MAME and other games.
    But with default config, there is just the mousepointer that is moved.
    Now I think of two possibilieties:
    1. Map Arrow-Keys to the Joystick within Poseidon.
    But I haven't found the correct settings for that.
    2. Teach MAME to use USB-Input, but I can't see this option, too.
    Any help on this?
  • »28.12.04 - 07:43
    GMKai
    the latest update is already installed.
    as i don't know previous ones that detailed, I can not say what has changed.
    but i miss "more practical" settings
  • »28.12.04 - 10:23
    realstar
    Posts: 298 from 2003/2/24
    Make sure in Poseidon prefs "Devices->yourgamepad->settings"
    that lowlevel library emulation is set to "port1: merge with usb".
    [ Edited by realstar on 2004/12/28 11:56 ]
  • »28.12.04 - 10:54
    Posts: 1087 from 2003/3/24
    That USB-Joystick is it an anlog one or digital, and is it the CompPro?
  • »28.12.04 - 10:57
    Posts: 1932 from 2003/10/19
    Make sure you installed the update CORRECTLY and that everything shows as updated. You need to do a version in the shell to be sure and look in the prefs. I had the same problem and noticed I missed a startup-sequence entry. Once I corrected that all the game pads I've tried have worked fine.
  • »28.12.04 - 13:30
    GMKai
    poseidon.library V2.2 in mossys:libs/
    Trident is V2.0
    hid.class V1.5
    The device is an Competetion Pro USB-Joystick, it is recognized as "USB 2A4K Game Pad" within Trident.
    The line
    PoseidonROMUpdate
    is set just before
    Iprefs
    But I can't find an option to combine lowlevel.library with the Joystick in the told window.
  • »28.12.04 - 17:31
    GMKai
    i have been told that my problem can be in connection with lowlevel.library.
    there is one present, but i can't remember where it came from.
    from what aos/mos version do i have to take the lowlevel.library?
  • »08.01.05 - 12:11
    Did you edit the user-startup file like the docs tell you to? It must be dont to get the update working correctly, a files needs to be run at startup. Read the install docs again/
  • »08.01.05 - 12:58
    pegasosuser
    Posts: 138 from 2004/4/9
    Hello Kai Stegemann,
    the versions i haved installed are:
    Trident is V2.0
    and hid.class is V1.6 <= You have older version.
    Greetings Cor van Londen.
    [ Edited by pegasosuser on 2005/1/8 22:04 ]
    PEGASOSII G4@1Ghz Registered MorphOS2.5 & AmigaOS4.1 1024DDRam ATI RADEON9250-256Mb(128Bit) Creatieve Soundblaster Live! 2 x HD MAXTOR U-ATA133 160Gb 8Mb-Cache Plextor DVDR +- RW 708A 2Mb Buffer ONLY PEGASOS MAKE IT POSSIBLE!
  • »08.01.05 - 13:02
