MOS Media woes
    Aaron
    Posts: 127 from 2003/6/14
    OK...
    I installed the files in Classes:Multimedia, I put them in
    LIBS:Multimedia, and I tried them in their MOSSYS: counterparts. I
    even put them in dh0:multimedia and even my Weather and Seventh Sense
    directories.
    Neither Weather or Seventh Sense will work. I get nothing with
    Weather. I at least get the Seventh Sense window.
    Snoopium says that both programs are looking for
    Multimedia/multimedia.class (with no device or assign) and failing.
    What am I doing wrong?
    --Frustrated N. Cranky
    --Aaron Diezman
  • »05.01.05 - 07:12
    GK_LKA
    Posts: 481 from 2004/3/28
    They should be in MOSSYS:Classes/Multimedia. It works.
    [ GK / LKA Team ]
  • »05.01.05 - 07:45
    Aaron
    Ah ha! That did the trick. I guess I didn't try that afterall.
    Thanks!
    I can't connect with anything though. I guess the ISP firewall is
    getting in the way as it does with ANYTHING cool!
    I just have to wait until I move in a couple of months.
    --Aaron
    [ Edited by Aaron on 2005/1/6 6:37 ]
    --Aaron Diezman
  • »05.01.05 - 10:35
    Aaron
    I just reset the proxy on SeventhSense and that works now.
    --Aaron
    --Aaron Diezman
  • »05.01.05 - 10:44
    hooligan
    Posts: 1948 from 2003/2/23
    @Aaron
    I had the exact same problem and Snoopdos resulted the same. Thank god for irc and #morphos ;-)
  • »05.01.05 - 12:58
    Posts: 1932 from 2003/10/19
    Great! I got it working now as well, its a great app. I hope more
    comes from it soon.
  • »05.01.05 - 13:40
