Hollywood question.
    matt3
    Posts: 784 from 2004/2/10
    How good is Hollywood for program tactical type games where you would have to track various statistics with multiple players. From reading the website the graphics movement and manipulation is handled easily.
    Thanks for the input.
    Matt
  • »01.01.05 - 16:15
    Robin
    Posts: 741 from 2003/2/24
    Hollywood is surely a great language.
    As long as you dont need to handle collisions.
    The second thing that is a little bit different
    to other languages is its one-instruction per commandline.
    You cant say a = 2*b+3, in Hollywood this is written like this
    a = mul(2,b)
    a = add(a,3)
    Hollywood takes full advantage of MorphOS speed. You
    can get easily high fps for an 800x600 window with lots of
    tiles.
    I really love it ! :-)
  • »01.01.05 - 16:30
    matt3
    Thanks for the great feedback. Can you also push/pop stacks or database tables? I noticed on their website it can read files but, I wasn't sure what the file contents could be dumped into.
    Could I call Hollywood a true development enviroment? Akin to say Basic or Pascal?
    I'm glad to see that you can use MOS to such a degree, seems like you can save a lot of development time.
    Thanks again for the help!
    Matt
  • »01.01.05 - 17:54
    Robin
    Hollywood is a interpreted language. You can run the
    script by passing it to the interpreter or compile
    it to have the interpreter and the data in an exe.
    The script is a normal textfile. So its up to you
    what environment you use for development.
    Hollywood has no inbuild editor or sth.
    For databases and stacks, I think it's safe to say
    thats not included. You would have to make your
    own data-management. Hollywood knows different types
    of variables. Float,Long and String. You can have an
    array for each of them. So if you read a file line
    by line you can put each line into an array of strings.
    If the variable is called lines it would be used like
    in other languages lines[0],lines[1] etc
  • »01.01.05 - 20:35
