DivX / Xvid encoder for MorphOS ?
    BigGun
    Posts: 150 from 2004/6/18
    I've just got one of those new DVD-player
    for which can play DivX movies as well.
    I wonder if there is a tool for MOS
    to encode a movie to XviD or DivX ?
    I don't want to use Windows to feed my new player :-)
    Thanks in advance
    Gunnar
  • »28.12.04 - 16:45
    tokai
    Posts: 1289 from 2003/2/25
    mencoder is available here in morphzone download area (but it's maybe hard to use for beginners, commandline only).
    but i ripped+encoded a few dvds with it already, works great. *dancingmrbananaandstuff* :-)
    regards,
    tokai
    edit:
    0.93 version is the best imho. better get that one
    [ Edited by tokai on 2004/12/29 2:19 ]
  • »28.12.04 - 17:18
    BigGun
    Thanks for bringing mencoder to my attention.
    Something with a nice gui would probably be easier to start with but I'm not afraid to read the instruction to use mencode from command line. :)
    Will I need an extra tool for ripping the DVD to disk?
    I think copying the DVD to harddisk before converting
    will be a good idea and will have the advantage to allow me
    to return the DVD faster...
    Tokai, how long does a 2pass DVD convertion take on Pegasos ?
    Cheers
    Gunnar
  • »28.12.04 - 17:44
    MarK
    Posts: 641 from 2004/1/25
    It strongly depends on options and transformations... When I was converting a DVD movie to DivX, it made between 6 and 18 fps... Depending on target resolution...
    Made on P2/G4.
    Bye, MarK.
  • »30.12.04 - 09:13
    Wishmaster
    Posts: 342 from 2003/6/29
    6 fps is sounding a little bit slow for a G4.
    Is this an Altivec enhenced MEncoder or the G3 version ?
    Pegasos PPC
  • »01.01.05 - 11:21
    analogkid
    Posts: 711 from 2004/11/3
    is there a new mencoder version available, with the better DeCSS stuff the latest mplayer has built in ? With the old mencoder I can't rip DVDs from my DVD-ROM :(
    [ Edited by analogkid on 2005/1/1 22:06 ]
  • »01.01.05 - 14:05
