MPlayer & encrypted DVD
    Posts: 1077 from 2003/3/24
    How can i watch encrypted DVDs with MPlayer?
    I knwo that MPlayer can show encrypted DVDs on Linux, is that possible under MOS???
  • »02.11.04 - 06:36
    Kaczus
    Posts: 199 from 2003/9/6
    Unfortunately it isn't possible :(
    Kaczus/BlaBla & AUG-Lodz Happy Pegasos User
  • »02.11.04 - 09:21
    thefab
    Posts: 92 from 2003/8/19
    sure, IT IS possible.
    just use the same parameters.
    do you guys never read the docs? ;-)
  • »02.11.04 - 09:43
    @ thefab: I did but i found nothing, how to with what type of comandline in shell or with tooltypes.
    Could you be so kind and share you knowledge with me :-)
  • »02.11.04 - 11:22
    Kaczus
    are You sure?
    libdvdread: Using libdvdcss version 1.2.8 for DVD access
    libdvdread: Could not open ide.device:1 with libdvdcss.
    libdvdread: Can't open ide.device:1 for reading
    Couldn't open DVD device: ide.device:1
    This is a efect when I try to do this...
    Yes in version 1.04 pre I can see this dvd, but only see. Voice and
    video isn't synchronised!
  • »02.11.04 - 14:42
    magnetic
    Posts: 2129 from 2003/3/1
    Of course its possible in MOS. I have been playing ecyrpted DVD since mplayer came out with Peg!
    Whats important is your drive. I recommend the LG 8161b drive for Mplayer/mos.
    magnetic
  • »02.11.04 - 16:39
    analogkid
    Posts: 699 from 2004/11/3
    is there a new version of Mencoder with the new libdvdcss code of the 1.0pre4 mplayer ? Only with the new MPlayer I can watch DVDs on my DVD-Rom Drive.
  • »03.11.04 - 08:32
    @ magnetic: You are right with my NEC 3500 DVD Burner i can watch encrypted DVD without problems.
  • »03.11.04 - 15:16
    BigGun
    Posts: 150 from 2004/6/18
    I can read DVDs with Mplayer 1.0 pre4
    But mencoder does not work for me.
    I've tried mencoder 0.91 and 1.0 pre3
    both fail with "Error compiled without libdvdread support"
    Any ideas ?
    Cheers
    Gunnar
    [ Edited by BigGun on 2004/12/31 0:19 ]
  • »30.12.04 - 15:16
    magnetic
    Its your drive..
    You need a supported drive that will play encrypted dvd AFAIk
    I recommend the LG 8161B
    there are other drives that work.. search threads here on mz
  • »30.12.04 - 20:23
    BigGun
    Hi Magnetic,
    I don't know I've tried three different DVD drives now. An LG 4081B, a Samsung and a Toshiba.
    I can read with Mplayer but mencoder does not even work with one of the drives.
    Maybe my mencoder version is just too old.
    Gunnar
  • »31.12.04 - 18:44
