SFS questions
    catohagen
    Posts: 297 from 2003/5/20
    I've been downloading some movies with ctorrent lately, and now the disk is behaving strangely.
    Files get lost or corrupted, or something, the movie i'm downloading now is 4.5GB and
    divided into 94x50MB, and i've completed the movie 3 times now, there's 4522 'parts'
    but some files are filled with garbage, and wont unpack.
    If i download the movie (4522/4522) i get errors with unrar(not a rar file)
    and if i restart download with ctorrent it detects 4083 of 4522 parts complete
    even if its completely downloaded before.
    I tried to copy the files to another partition but whole machine hangs at a specific file,
    or not hangs, but halts, mouse works but no icons respond and cpumeter stops.
    Anyone have a clue whats going on ? SFS to blame ? the hd is a new seagate barracuda 200gb
  • »28.12.04 - 13:51
    Posts: 1521 from 2003/2/24
    You have pre-April Pegasos, don't you?
  • »28.12.04 - 14:22
    catohagen
    no, i traded it in for a pegasosII-G3
  • »28.12.04 - 14:30
    Oh. Then it is just corrupted filesystem. It tends to happen with SFS... :-S
    Get SFSsalv and try safe as many files as possible :-/
  • »28.12.04 - 15:02
    Posts: 1932 from 2003/10/19
    I had the same types of problems not long ago. I keep a partitopn now that just has my system backed up. I would do as above and hope you can salvage most of the files. SFS should be backed up all the time.
  • »28.12.04 - 15:54
    AyoS
    Posts: 410 from 2003/8/13
    I have about 25 gig of movies in various formats, and no corruption problems with sfs??
    my partitions are as follows:
    morphos 256mb ffs
    work: 4gig sfs
    katos: 20 gig sfs
    storage: 51 gig sfs
  • »28.12.04 - 18:44
    Aaron
    Posts: 127 from 2003/6/14
    I have a partition on my system for my brower's cache and it gets
    corrupted every couple of months or so. As a matter of fact, I had to
    reformat it yesterday.
    I'm happy that my theory was correct and it is an SFS problem.
    --Aaron
    [ Edited by Aaron on 2004/12/29 22:59 ]
    --Aaron Diezman
  • »29.12.04 - 02:56
    Posts: 649 from 2004/4/15
    Just make a format&verify and you will
    recognize that your hdd is broken!
  • »29.12.04 - 14:03
    AyoS
    I am not sure that I agree with this synopsis. I have run my peg II as my main computer for 1 year now and only had one sfs crash. and that was in the first week I installed morphos. since Feb. 2004 I have not had a problem with sfs. Now I don't exactly know what caused the problem, but I use this computer for surfing, via Ibrowse, voyager + Aweb Daily, sometimes using 2 or three of the above browsers at the same time. I do not cache to memory so all cache is disk based on an sfs partition. when I get home from work I will post my settings. I have nothing but good remarks about sfs, It is far more stable than the old FFS was.
  • »29.12.04 - 14:18
    ChatDEau
    Posts: 248 from 2003/4/4
    Me neither. I never had any problems with SFS, apart when I was using it with my A1200, and I do use it eavily on Pegasos since 2002 now (and I have a Pegasos I April 1).
    I once had a problem with YAM corrupting files and other people told me it also corrupted partitions (it may have been fixed with newer versions tho).
    If you use Secondary IDE on Pegasos I, this can also be the problem, it has some (DMA?) bug (dunno if April II fixed that).
    Fred
  • »29.12.04 - 16:04
    Hawk
    Posts: 204 from 2003/12/29
    When I download some video with mldonkey for MorphOS, the file is initially created "full-size". If I try to play that file before it has been fully downloaded, mplayer starts playing weird stuff! Even fragments of videos from other partitions! O_o
    So I guess there should be something wrong managing "empty" files.
    But the partition itself doesn't seem to be corrupted.
    Another problem I have detected is using the BSD commands (ls, rm, mv ...). They sometimes lead to errors (files not being removed, and stuff). The same kind of errors you may find when mounting an SFS partition from Linux.... I had to format one SFS partition cause I messed it up with Linux. It's OK to copy things to the SFS partition, but better don't move or erase things from the Linux side.
    The only thing I can say it's that there is so much corruption in this world, that it has finally arrived to your HD !! good luck!!!  :-o
    Pegasos II G3@600Mhz (no fan) 512MB RAM (1 slot)
    -- Maxtor 6Y120P0 120GB, 7200 rpm -- ATI Radeon 7500 - (64MB, TV-out)
    -- Minuet Slimline PC case -- MorphOS 1.4.5 + Gentoo
    EFIKA
  • »30.12.04 - 00:37
    AyoS
    Here are my SFS settings:
    Volume name work:
    sfs version 1.201
    cache misses/accesses 0% 4373/1458285
    Buffer lines 32
    Read ahead Buffer size 16384 bytes
    Memory Used by SFS buffers 512 kb
    Mode Copyback
    activity Flush timeout 10 s
    inactivity flush timeout .5 s
    Maximum Filename length 107
    Maximum recycled entries 256
    Volume name katos:
    SFS Version 1.201
    Cache misses/accesses 1% 3944/332645
    Misc Info TD64
    Buffer line 516
    Read ahead buffer size 16384 bytes
    Memory used by sfs buffers 12% 8256 kb
    mode Cobyback
    Activity Flush timeout 20 s
    same
    same
    Volume name storage:
    SFS Version 1.201
    Cache Misses/Accesses 3% 23267/598891
    buffer lines 32
    read ahead buffer size 16384 bytes
    Memory used by SFS buffers 0% 512 kb
    - rest is the same
    I have movies on my katos and storage partitions
    storage has 12 movies plus full 5 seasons of Babylon 5 in Mpg and AVI
    format (babylon movies included in the 12) katos has 10 or more dvd
    .VOB files that i watch occasionally All of which I have on dvd
    anyways.
    I use these partitions daily and have never had a problem except when
    I first installed and was playing with the settings to try to squeeze
    more performance. I am not sure what I did to screw it up, but works
    fine now.
    katos1
  • »31.12.04 - 01:05
