STFax 4
  • buh
    buh
    Posts: 68 from 2004/2/2
    Is anyone using stfax's 4 free version on mos ?
  • »15.10.04 - 11:33
    ChatDEau
    Posts: 248 from 2003/4/4
    @buh
    There's a free version? Where?
    Do you mean a demo?
    Fred
  • »15.10.04 - 16:07
    ChatDEau
    @tokai
    Oh yeah right, STFax4 is on aminet, HERE.
    Fred
  • »15.10.04 - 17:22
    docgeddy
    Posts: 37 from 2003/7/31
    not the free version, but the registered version, which results in the same ;) It works without problems, with the needed MCCs installed.
    DocGeddy
    Member of Butterfly Army
  • »15.10.04 - 19:11
    ChatDEau
    @ALL
    Lo there!
    I did install STFax4 from Aminet and it works very well.
    The only problem I got now is that I can't get to configure TurboPrint to use the provided STFax printer driver (to print directly from any software into STFax which then converts it to fax format).
    Could someone help please?
    I really need to send some faxes ASAP.
    Thanks,
    Fred
  • »02.11.04 - 20:48
