MorphOS Developer
Posts: 1520 from 2003/2/24
3. How to link the library to get strlen(), memset() etc.?
You don't. At least not yet. Only solution is that you write memset(), strlen() etc replacements...
4. My test skeleton (more or less the same as the skeleton in the devkit) compiles and the test program compiles but if I call the test function, nothing at all happens?! No crash, no action.
Hmm... You don't need gates anymore. You can simplify jumptable:
static const APTR FuncTable[] =
(APTR) FUNCARRAY_32BIT_NATIVE,
(APTR) LIB_Open,
(APTR) -1
This creates jump table accessible from both PPC and 68k code (== AmigaOS 3.x compatible).
(FUNCARRAY_32BIT_SYSTEMV would create PPC only jump table.)
Could not find any error from library or test app though... it should work as far as I can see. But when creating inlines with cvinclude.pl you should use -root option too.
