Moderator
Posts: 126 from 2003/2/17
@FALCON-1
I've seen somewhere (perhaps in my IRC logs) that one of the first project you'd work on would be to port lpr.device to MOS ... any developpement?
source of the last aminet version is fully ported to gcc and compile fine.. but the binary doesn't work... so I have to find what's the problem...
to test your installation with LPR.device
setenv lpr.device.0 (don't forget .0) and only use HOST, PORT and RAW arguments.
using a PC print a nice picture to a file and burn this file on a cd to put it on the pegasos. then make a mount list with lpr.device unit 0 (I can gve you one already done if you need it) then simply copy the file to the volume created by your mountlist (LPR0 here) If it works, then the problem is TurboPrint, if not, mail me in order to find what's wrong.
BTW OpenDevicePatch is of nearly no use for you it's simply for programs which don't call printer.device but use paralell.device directly... so it intercept them and send them to lpr.device, that's all... so no real use...
[ Edited by FALCON1 on 2004/10/29 7:37 ]
