Java 1.4.2 SDK and newer
    igracki
    Posts: 469 from 2003/2/24
    BTW:
    Would it be possible to write java-apps for handys with this sdk?
  • »20.10.04 - 10:48
    td741
    Posts: 224 from 2003/4/2
    There were several attempts at porting Java to AmigaOS.
    I think there's a Kaffee port somewhere, one old one has rudimentary support for some AWT classes and that was it.
    There was another recent Java port but it currently insn't completed. Again, I believe the GUI parts aren't fully coded yet.
    Your best bet, at the moment, is linux. Otherwise, if you have an XServer for Amiga, you might be able to compile Kaffee and have it use the Xserver? (Not 100% certain on that one though.)
    Steph
  • »20.10.04 - 12:15
    poundsmack
    Posts: 1346 from 2003/6/7
    when you say Kaffee do you mean Kaffe?
    "Poundsmack, official morphzone thread creator" -LorD
    "Wanna be lord of the avatars." -JKD
  • »20.10.04 - 14:21
  • News Moderator
    News Moderator
    Darth_X
    Posts: 571 from 2003/2/10
    http://gcc.gnu.org/java/
  • »20.10.04 - 17:53
    aliem
    Posts: 85 from 2003/12/11
    JAmiga could be a really good project and it will be a native version ... so more supported.
    It also will use the GNU Classpath.
    I hope that they need more support: testing and developing
  • »21.10.04 - 19:31
