Moderator
Posts: 137 from 2003/7/1
Hello!
Since I rebooted my computer I have a really xtrange problem.
The drag and drop doesent run and the skins doesn't run fine.
Any ideas?
What can be?
»17.10.04 - 23:00
Posts: 381 from 2004/9/7
Try install MorphOS from the beginning.
»18.10.04 - 00:32
Posts: 248 from 2003/4/4
@Doraemon
As Phantom206 said, reinstall MOS from scratch. But, before doing so, I also suggest you backup your actual SYS: into another directory to keep a copy of already modified files.
And then, you can compare files and identify where the problem comes from so it doesn't repeat.
Fred
»18.10.04 - 21:04
